928 Forum 1978-1995
Sponsored by: 928 Specialists
blower removal
Old Oct 11, 2003 | 02:58 PM
RazorRacer's Avatar
RazorRacer
Unhappy blower removal
Ok. The hood is off. I'm ready to pull the blower out. Where is that third phillips head bolt at the bottom of the blower? I can't see it when I push up the flap. Do I have to remove the whole assembly in the passenger footwell?
Old Oct 11, 2003 | 03:03 PM
RazorRacer's Avatar
RazorRacer
The workshop manual says:
"To accomplish this, open flap of intake housing (move control switch lever to "AIR COND."). Unscrew mouting screw with a screwdriver inserted through open flap.
What does...move control switch lever to "AIR COND."...mean? I'm under the passenger footwell pushing the flap up with a screwdriver and sliding the control switch lever back and forth. Nothing seems to change under there.
Old Oct 11, 2003 | 03:24 PM
GlenL's Avatar
GlenL
Funny coincidence: I was just pulling the ventilation blower fan off the parts car. Reflected to my son that it's nice getting things apart that don't have to go back together.
Is the flap you're describing the drain flap? Not sure how that helps. There looked to be three screws from the top.
I got the fan out by springing the three clips that hold the halves of the housing together. Didn't try to get the bottom out as I wanted just the motor.
The three screw on the top of the housing aren't enough as the fan is too deep. Guessing that you'd be able to get the screws out once the top is off, but that wouldn't be much help. Everthing is pretty tight. I don't think I'd be able to get the clips back on. Made me wonder how the heck they put it in there in the first place.
Not much help, I know. If you're stymied later, post or PM me and I'll take a look. We knocked off for the day as it started to rain and covered the hulk. Maybe after dinner or certainly tomorrow I could take another look and post better info.
Old Oct 11, 2003 | 03:26 PM
2V4V's Avatar
2V4V
Razor,
Which of your cars are you working on? The 84 has a different climate control than the 78. IIRC, the 78 could even have a full manual model, though it may be auto.
Rules of engagement change on cars made on either side of the 84 line of demarcation.
Greg
Old Oct 11, 2003 | 03:30 PM
RazorRacer's Avatar
RazorRacer
What should be a 2 hour job tops is taking all day.
I updated my profile. The 78 is a 911.
So the 94 928S will not let me remove the blower because the bottom phillips head bolt cannot be accessed. I'm thinking that I have to remove the whole assembly in the passenger footwell.
Any help will be greatly appreciated.
Old Oct 11, 2003 | 03:55 PM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
Depending upon the model, the third screw may be on the edge of the grille, or it may be inside the opening. Either way, you shouldn't have to remove anything inside the car other than the one screw.
Old Oct 11, 2003 | 04:03 PM
RazorRacer's Avatar
RazorRacer
WallyP,
I'm beginning to think someone put an updated grille that covers the screw. There is a platic post where the screw should be. I think the updated grille is covering access to the screw. Would that make sense?
Craig
Old Oct 11, 2003 | 04:10 PM
RazorRacer's Avatar
RazorRacer
I GET THE DUMB *** AWARD FOR TODAY!!!
WallyP,
Thanks to your advise and the advise of others on this BBS, I found the screw. However, it's a bolt that was covered with black silicon rubber. Man, I feel stupid, but happy. It was not inside of the...now torn up flap...but is was on the "trailing edge" of the grill. The angle looked weird so I never suspected that was it.
Now to carry on...
