Classic 9 / Robert Budd Interior Install
So does the pod we send in have to be the same color as the one we receive back?
I ask because i have a brown core id like to send, but need a black one in return.
Itoolio i apologize for feeding into the thread hijacking, I will continue my communication through PM.
I definitely think you should go with a stitched pod to match your beautiful new dash
Leather covered pods were always a factory option...and look quite nice.
And agreed re: stitched pod. The other solution looks nice, but not sure how well it would fit with all the leather that would surround it. Email already sent to Budd
Well unfortunately some people on this site take it personal when outsiders have an opinion ... I notice it only happens on the 928 page ... I been driving 928's since 1985 and truly love the cars .. Didt mind adding my own personal style to the cars until after I had a talk with a car designer .. I have soften a bit since . Now I just need to find another set of 16 inch phone dials ...lol
I've got no problem with anyone adding anything to my threads. I try to learn as much as I can here, and I welcome any/all education I can get. And agreed re: stitched pod. The other solution looks nice, but not sure how well it would fit with all the leather that would surround it. Email already sent to Budd
** ahem **
As a Vegan Environmentalist, (aka Vegamentalist) I add my voice in objection to this heartless unwarranted massacre of countless Baby Cotton Bolls in the making of your precious stitching thread.
How many Cotton Boll lives are enough for you? Philistine !
Dan, I didn't want to say anything, but, I happen to know that he also requested "special" grain leather, made from baby harp seals.
Seriously Ryan your interior is AWESOME.
Bravo.
Only one complaint..... more pictures, please ??
Dan
Bravo.
Dan
Thanks for the kind words, gentlemen.
So...no more interior pics for a few days. Next thing I need to put in is the console, and it has some issues I need to fix.
First - the frame that the shift boot attaches to is cracked towards the top and as a result, there's nothing there to hold it in place. Also, that section being broken allows the console to shift outward a bit, so I cut and drilled a metal bind strip and then attached it to the bottom screw holes:
I had read some other threads about repairing the upper connector with a concave piece of sheet metal, but I didn't think that one of the sides had enough plastic remaining to connect the sheet metal to. So....I drilled a hole through the console and through the shift boot frame, inward enough to not interfere with the boot itself. I also melted a slit in the console with a heated-up flat-head screwdriver, and then looped a twist tie through it and through one of the holes on the metal binding strip.
I'm hoping that I'll be able to reach through the hole for the ash tray and tighten them up once the shift **** and boot are installed.
Next up - repairing the area for the window / sunroof / rear-wiper switches. A couple of the flanges that the switches tension to are broken, so doing some thinking about how to address those.
And Dan - I had Harp Seal steaks for dinner, with a side of koala steak tartar. Both were delicious.
Hi Ryan,
The flanges for my window switches were in pretty bad shape. I picked up a couple 1/2" x 6" pieces of thin brass at the hardware store. I used what was left of the existing flanges to make the two strips into the upper and lower apertures for the switches. There was plenty of area to JB weld the strips in place. The switches sit maybe a 1/32" high but since they're all the same, you don't notice it.
Good luck, and keep up the good work,
Dave
Dave
