Alignment shop in Maryland
03-31-2016 | 09:39 AM
Does anyone in this area know of a good alignment shop? Just finished replacing tires, ball joints, control arm bushes and tie rod ends.
I somewhat suspect I may need an alignment..
03-31-2016 | 12:28 PM
You definitely need an alignment. I'm in Frederick, MD and interested to know of a good alignment shop as well.
03-31-2016 | 12:33 PM
Really? My car is stored in Baltimore. But I get up to Fredrick weekends when I'm stateside.
03-31-2016 | 12:40 PM
Quote:
Originally Posted by
scottpeterd
Yes, anytime you replace something in the suspension that's adjustable i.e. ball joint and tie rods, everything needs to be aligned.
Baltimore is less than an hour from Frederick so if you find.a good alignment shop let me know. It would be worth the drive.
04-29-2016 | 12:57 PM
ASM Performance would be my first, second, and third choice.
04-29-2016 | 04:05 PM
pls check threads for special 928 alignment needs ... otherwise you'll be buying new tires in about 200 miles
04-29-2016 | 04:18 PM
Sears has the Hunter Alignment system and aligns for less than $100
04-30-2016 | 11:38 PM
Darien Nunn
Russel BMW in Ellicott city had a non-lift alignment system, and yes the alignment worked out.
