928 Forum 1978-1995
Sponsored by: 928 Specialists
S4 not returning to idle when hot
Old 03-01-2016, 06:47 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Originally Posted by Paddcomp
I've checked and checked again, but don't have the equipment to pressurise the intake. Wouldn't a leak be more consistent and there all the time. I've checked the vacuum at idle as -20hg.
Brian
Here's how to build what you need to pressurize the intake.
Dwayne's Intake Refresh Write-up
Start at post # 4
Old 03-12-2016, 11:57 AM
Paddcomp
Paddcomp's Avatar
I changed the accelerator and throttle cables today, pedal cable had some wear on the inner sleeve but no fraying.
Adjusted and test driven, high idle returned after 5 minutes. I could see there was slack in the throttle cable and there was no clicking from the TPS. Diagnosed the throttle plate sticking open, independent of the cable position. Snapping that quadrant open to closed wasn't enough to overcome the stuck valve, until cooled down.
The intake is now off again and the throttle valve is free. Any suggestions on a way forward?
I'd like to test the throttle body and simulate the heat causing something to move and stick. This way I can test the throttle before putting it back on the car. I'm thinking on putting it in the oven at say 85C then try to realign the plate or whatever's causing the problem.
Brian
Old 03-12-2016, 06:34 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,494 Likes on 1,403 Posts
if you removed the throttle plate from the shaft then you have it installed incorrectly,
best guess is to loosen the 2 screws that hold it in the shaft,
then snap the throttle closed a few times ,
and then tighten the screws this should recenter the plate.
Old 03-12-2016, 06:50 PM
Paddcomp
Paddcomp's Avatar
Hi Merlin,
That's how I did it when I put it back together. I'll try it again if there isn't a procedure to set it. Do you see any problems testing it in an oven at 85C?
Brian
Old 03-12-2016, 07:48 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
no that shouldnt hurt anything.
BUT before you oven test ,it could also be possible that you have the plate turned around and the edges are binding.
IE the part of the plate that was facing to the rear of the car when the plate is closed might now be facing forward
Old 03-12-2016, 11:18 PM
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,318 Likes on 499 Posts
... BUT before you oven test ,it could also be possible that you have the plate turned around and the edges are binding.
+1.
From Dwayne's site.
Old 03-13-2016, 02:04 PM
Paddcomp
Paddcomp's Avatar
Thanks for the feedback, it might be easier if I show some pictures of the installation.
This is the installation now with the throttle body upside down.
And the springs
How it was before the intake refresh
The arc on the plate is in the same place, and the plate moves smoothly with the TB cold. I assuming that the alignments not 100% and somethings moving when warm, I could either oven the whole thing or use my heat gun on the plate only to see if I can reproduce the problem on the bench.
Thanks.
Brian
Old 03-13-2016, 05:10 PM
the flyin' scotsman
the flyin' scotsman's Avatar
the springs are not installed correctly; there should be a plate under the outer nut.........suggest taking apart fully clean and rebuild.
Also the arm where the cable attaches is bent.
From Dwaynes epic:
Old 03-13-2016, 06:45 PM
Paddcomp
Paddcomp's Avatar
I presume these parts aren't available separately? Well spotted.
Brian
Old 03-13-2016, 11:14 PM
the flyin' scotsman
Hopefully all parts are there but misassembled.........take apart and review against the pic.
good luck.
Old 03-15-2016, 06:30 PM
Paddcomp
Paddcomp's Avatar
Default TB Plate sticking when heated
Made some progress today, firstly I purchased another plenum and complete throttle body from a breakers for spares / reference.
Then I tested the throttle plate with my heat gun on my original TB, and in less than a minute the throttle plate was sticking and wouldn't close. I loosened the screws and allowed the plate to reseat, but this had no effect. I took the plate out and heated again and the shaft itself doesn't stick.
With the plate removed I noticed some end float in the shaft, about 2-3mm, is this correct? I refitted the plate and heated again, but couldn't free it by moving the shaft on the end float (which isn't there with the plate installed as the plate stops it moving).
Also tried my TB with the plate from the other TB, no difference.
Any ideas on what to try next? Do I just rebuild the replacement TB with new bearings, not sure how this can be different to mine as it's cast.
Old 04-02-2016, 08:31 AM
Paddcomp
Paddcomp's Avatar
Default Solved High Idle S4
Replacing the throttle body cured the high idle. I'd like to have found the problem with the original TB but it wasn't to be.
Old 04-02-2016, 09:48 AM
FredR
FredR's Avatar
Did you replace the bearings/seal? This is a known common aging problem with the TB. Whether it would explain your issue I do not know but if you have a square peg in a round hole..?
Rgds
Fred
Quick Reply: S4 not returning to idle when hot
