Race Car Repairs after Mid-Ohio shunt
#31
I think Carl already has a nice alloy PS reservoir.....obviously the advantage of adjustable pressure, ability to move weight toward the rear, and eliminating the belt drive power losses make it all pretty attractive.
It also means the power steering works even after you blow a motor.....
#32
That's all brand new parts sold in a "turn key" kit.
You can find pumps for $300 or less. Make your own lines and harness while re-using the factory reservoir (the one in that kit is $110).
I've talked to guys who snagged one of those pumps at a local pick-n-pull for $50.
I dunno Mark, I haven't seen you at my race courses much... and I have never been to your tracks in CA so I'm not sure where you pull these comparables like you do. But never mind. Its off topic. this thread is not about driving or lateral G's. It's about something else - leave it that way.
Wow Hacker... $1,125? Looks like the 928 Power Steering is going to have to go a little longer...
http://www.fastfreddiesfabrications....p?id_product=4
where do you think the energy will come from to drive the powersteering pump? if its electrical, its coming from more load acting on the battery and "belt driven" alternator. adjustable pressure is good for slow turns at lower RPM levels, but i dont think the weight moving rear ward is even a rounding error in balance at best. the pump weighs 3lbs. by the way, its going to be much more efficient than driving it by an electric motor which is only 80% efficient at best, and that electricity has to come from the alternator, which again , is belt driven.
but, the best point is that you get power steering when you blow your engine. Now, thats a notible advantage?
#33
Developer
Jim, there's only so much $$ in a year. The new rad, intercooler, and instrument cluster have it all for this year. I am not opposed to an electric power steering pump at all. Kinda like the idea, actually. Just out of money.
To hear you speak, you must have an electric in your racer. How do you like it?
#34
Developer
I do wonder what the parasitic loss is of the belt-driven system off-idle. They are designed to make sure power assist is available at engine idle speed and at rest. Once the car is rolling, steering effort is naturally reduced anyway. Shortly after idle the hydraulic system is producing too much pressure. and the by-pass valve opens. Basically, at high-way/race speeds, that bypass valve is open and the parasitic loss should be very very low. Perhaps even lower than the electric motor on the alternator. (Kibort's point).
#35
Developer
Here's the first mock-up. Intercooler on the driver's right and radiator on the driver's left. NOTE: visual is deceiving as the boxes include the end tanks for each. The actual core sizes between the end tanks are smaller.
Both the intercooler and the radiator are larger than they were last year, but I will give the numbers to the manufacturers and let them tell ME if they are big enough for my application. Then I can adjust some dimensions up or down to get a package that works.
#36
Carl, what is the main purpose of converting your radiator to a tilt version? Usualy the corvette guys will do this for room and plumbing ease, as well as being able to use a large radiator that wouldnt normally not fit if standing up with the aero packages they run.
are you going to employ a hood vent?
#37
Carl,
Toss in a couple of side drawers, and you're home free...
#38
Developer
We have been running vents in the hood for years. These pics show them well.
#39
Those are exactly the reasons we are doing it. Fit a bigger rad, and get the rad away from the engine. I think it will also smooth the air stream under-hood somewhat... the airflow around the motor is a tortuous path and this way we can "aim" it up and at those exit louvers so it does not have to smack the front of the motor as much.
looks good.
#40
aero pressure zones for optimizing hood vent design
This shows the pressure zones around the hood front area. i verified this with pressure sensors at up to 130mph.
It basically shows that if you have the radiator leaning forward, you can have a nice opening to the lowest pressure area which will end up right in front of the engine, to where the op of where the radiator was previous located.
#41
Developer
Excellent points.
Our focus in the wind tunnel was reduction of drag, and we spent no time on trying to optimize draw from under the hood. At $600 an hour, you get very choosy about what you want to effort! So although I have some good drag and leading edge/trailing edge data, I do not have any data on the location of the low pressure zone on the hood that's any better than Porsche's old chart which you have already posted.
Looking at the last photo posted below... they slowed the wind tunnel down to where you can stand in the tunnel with the car and photo the smoke stream at various points. I was confirming that my guess on where to place the hood louvers to evacuate the engine bay was good or not - they look to be in an area of smooth laminar flow, which should be a nice low pressure area.
#42
Developer
BTW: we were able to lower our Cd (Coefficient of Drag) to 0.25. This is a gain equivalent to adding 95 HP to the engine. My best information is that the original 1978 928 had a Cd of 0.38, which was lowered to 0.33 in 1986.5/87 with the changes to the front and rear bumpers, smoothing in the lights, adding the belly pan, among some other things.
#44
notice the wind tunnel indicator stream... it breaks up (starts to stagnate) after the area where your main hood sticker is. (where the stream is tight)... put the vents there and you might greatly improve the downforce and flow pattern out of the hood.
i verified this on the track with pressure sensors. (and tufts that would point up out of the vents )
#45
Developer
True, lower pressure further forward, but the headers would be behind the louvers then. We have no cowl. Note hood meets the glass.
So louvers placed where they are (over the headers) so the air from the radiator could wash past the headers and carry some of that heat out.
Still a low pressure area, although perhaps not as low. A compromise.
Would like to not spiral off into a wind-tunnel discussion. OK?
