Wet Winter Weather Woes
I park the car on the driveway. When the weather's cold and wet I regularly have problems with the first start of the day.
It often falters on start up causing an uneven idle. If I drive conservatively it will probably clear after 10 to 15 minutes. If at any time I give it some gas, it will falter and become more and more lumpy until eventually cutting out completely.
It will always restart but it takes 4 or 5 restarts before the unevenness disappears and the car drives normally.
Any theories?
Any theories?
This is some quick servicing you can do to address your symptoms in light of the conditions they're exposed to.
Sounds like your next job is the intake removal.
Originally Posted by davek9
How old are the ignition wires, caps and rotors ?
Spray all electrical down w/ WD-40, old cars and dampness is never a good combo
Cheers!
Cheers!
Chronic Tool Dropper
The engine management systems rely on the coolant temp sensor (temp sensor II) to decide how much fuel and how much spark advance the engine needs when it's at different temperatures. The workshop manaul tells us the expected resistance at different temperatures. I recommend testing at the EZK and LH brain connectors, so that wiring and connection resistance are included when you test. If you get readings that appear to be too high, then go check the two loops at the sensor to decide whether the problem is the sensor or the wiring/connections.
