How Much Do S4 Cats Affect Power?
#32
Lag,
The power was "measured" with the use of a G-Tech Pro, 310 to the road to be precise. Rest assured, the day is coming....and it will yield positive results. Care to make more speculations on how poor flowing or little power the car will make? I'd be interested in hearing them as well as making note of new Lag-Algebra equations and assumptions. As I recall, the last estimate you made on 8 lbs was 317 at the crank. Do you really think the G-Tech could be off over 40 HP? I don't.
Oh Lag, perhaps I should send you a copy of the page out of an old Turbocharging book I have showing two simple log style manifolds on a twin turbo big displacement Mopar that made 800 plus crank horsepower. But we all know those Briggs and Stratton type of manifolds can't possibly flow any air...now don't we? Afterall you are Rennlist's resident guru on forced induction.
For the record, why not tell the entire Rennlist audience how much power this car makes. List all assumptions, then I'll get you the measured results. Afterall, your HP numbers are always spot on, right?
#33
#34
By John:
I’m sorry, but I just don’t have the time, however, but they are in one of these two links:
https://rennlist.com/forums/showthre...t=supercharger
By John:
By John:
By John:
By John:
By John:
By Z:
In playing around I was able to show my completely stock, normally aspirated, 2 liter, 180K+ mile, old Toyota beater repeatedly making over 1,600 rwhp. (Yes, that's really one thousand six hundred rear wheel horsepower, and not a typo) Torque was around 1,800 rwft/lbs.
#35
Hey Lag - Any math on my adding .6liters via a 106mm bore, with no more stroke, at 9:1?
I suppose from my limited math knowledge, that we could decontruct the 316 that the stock car produces with what it has, and then redo it for the .6 more liters? Is that even possible?
I'm so excited that I have a solid plan that does not include shipping my motor half way across the country to a town that we used to visit whilst I was in college (in Green bay by the way) so that we could find the easier chi....
Wait. This is about cars. Um, we used to drive down in my 86 conversion van, (with the fold down bed in the back) and introduce ourselves as the boys from the all-men's college up north and the girls would just fall all over us and...
Wait.
So, yeah, Lag, how about that math?
Wait.
#37
By Brendan:
Let’s start as usual doing the NA crank hp; it will be less due to the 9.0:1 cr. Assume a 4% loss of hp per point of compression:
New NA HP = 316 crank hp x .96 = 303.4 crank hp
Now let’s figure the hp per liter (hp/L) with the lowered cr:
hp/L = 303.4 hp / 5.0L = 60.7 hp/L
Since we now ‘know’ what the 9:1 engine makes per liter, we can now speculate the hp of a 5.6L engine with this configuration:
New HP = (hp/L) x (# of Liters) = (60.7 hp/L) x (5.6L) = 339.9 crank hp
By John:
Well Lag, you must be right. I guess the old girl only makes 317 at the crankshaft.
Sorry I ever questioned your math because it must be right.
#38
What did you do, add a extra "0" onto the weight?
#39
The vehicle weight is just one of the things that can cause the G-Tech horsepower results to be inaccurate. I definitely put a LOT more faith in the times that the G-Tech measures than the power numbers.
My old Toyota the ultimate sleeper? I sure don't think so!
