928 Forum 1978-1995
Sponsored by: 928 Specialists
Car wont start :(
Old 01-11-2016, 08:59 AM
yoni_d
yoni_d's Avatar
Originally Posted by Mrmerlin
NOTE dont install a used check valve or a used accumulator.
You will need 3 new sealing washers for the check valve.
NOTE dont try to reuse the old sealing washers, they will be work hardened .
Thus the ensuing amount of tightening will crush the metal short hose end and then this will deform and require a new short line as well as 3 new sealing washers.
Thanks Mrmelin!
By the way, do you know if fuel accumulator from a 911 with K-jet is the same as in 928 with K-jet?
Old 01-11-2016, 09:34 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,453 Likes on 1,378 Posts
you should look at PET to see if this viable
Quick Reply: Car wont start :(
