Camshaft locking tool picture wanted.
Captain Obvious
Super User
Super User
Anyone has a picture taken perpendicularity of the OE camshaft locking/profile tool that's used to check the camshaft timing (between the intake and exhaust cam) during the chain installation? I just want to double check my work and will just cut it out of paper.
Archive Gatekeeper
https://rennlist.com/forums/928-foru...ng-easier.html
https://rennlist.com/forums/928-foru...ol-9226-a.html
Though according to post #15, you don't need it.
im still wondering that point. you use that one dimension for two arrows on the cams, and if that distance is (something like 113mm) the cams are synched.. whats the tool for , "feel good"?
Archive Gatekeeper
Imre's car is an '85 (?) On the S3 cams, the pointers on the (exhaust? can't remember) cams are more like plateaus, and it's not entirely intuitive where to measure the distance to ensure you've got it right. So not unreasonable to doublecheck with the tool.
Captain Obvious
Super User
Super User
I'm just double checking a work that I'm doing on the someone else's car and I guess I'm more careful with this one than I usually am with my own.
Captain Obvious
Super User
Super User
Thanks for the link. I've saved the pic with the ruler.
Being a tooth out either way will not cause valve damage.
You can also rotate the engine by hand (with belt installed) and then do a compression test.
If the chain is out 1 tooth it will change the compression by 50psi.
a tooth off is a long way.... cant imagine that the little mark distances cant be absolute indicator that the cams are aligned right.
Captain Obvious
Super User
Super User
Colin, I'll be manually rotating it and might even do a leakdown test just to be sure.
I bought these:
Imre,
I have a set that I made up which You are more than welcome to use. I made them out of Masonite. I can also make them out of a plastic if that is any better but it is only for positioning purposes. You will still have to fine tune the timing anyway but this at least will stop you from having them out by a tooth.
I still cant understand how you would need the templates, because when you use the 113mm distance between marks, the cams cant be off. by the way, I used the real tools on my first cam job, and they work on GT cams as well the differences are subtle enough to not make a diff.
