Rear Main Seal
Rear Main Seal
I am in the process of removing my rear main seal. I was wondering how high the engine oil sat in the motor. Do i need to remove all the oil before i pull the seal?
Or can I get away with just pulling the seal
Thanks in advance
Thanks in advance
No, trust us, you'll be fine
The one thing you can count on is that the oil level will be below any part of the crankshaft. If it weren't, then the spinning crank would whip the oil around the crankcase, creating the "oil storm" that I mentioned. This can happen if the crankcase is over-filled, which creates a real mess-- oil is forced out everywhere.
Team Owner
are you familiar with how to remove the RMS ?
there is a trick to it.
Most important thing is to not damage the crank as you drive in the screwdriver
I'm always open to suggestions, but my method was the screwdriver approach...with care
I also read somewhere that its a good idea to pack the new seal with Porches high pressure grease.
Here's an install trick:
I've never got a installer (or something) to tap in the big rear main seal. Get it stuck in the groove and then use the flywheel to press it in. Use three bolts, tightening each a bit at a time, and it'll squeeze part way in. Then, remove the flywheel and nursed in the seal by tapping along the outside. Use a block of wood to cushion and spread the hammer force out.
