Timing belt Water pump and Poken tensioner install
#46
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Nope. 2 degrees advance to get a little bit more low-end. It really helped the car since the tires now break completely loose from around 3500-4000 RPM as it struggles for traction towards redline.
#47
Where's the steel disk for the hall sensor? It should be visible through the holes in the cam gear.
#48
in the end, the average HP was better from 4500rpm to 6600rpm.
you can feel the difference? that would be one sensitive butt dyno!
i noticed that too.
