Timing belt Water pump and Poken tensioner install
#31
if it doesnt, thats weird. cam timing can effect that i imagine. if at TDC, the driver side then becomes the unstable one and the passenger side is spring loaded.
I have never heard of anyone pulling a timing belt off and having the pulleys remain at the marks... anyone else here seen this??
#32
Yeh - I just did this a couple of weeks ago. Nothing moved at all - Car seems to be running fine except for a noise coming from the font of the engine that I am trying to track down. sounds like a bearing on one of the ancillaries - really hoping its not a crank bearing. Oil pressure seems to be fine.
#33
Captain Obvious
Super User
Super User
#34
Some cars cams will move, some won't. The only time I put the crank at 45 is when I'm removing cams/heads. Otherwise all the TB/WP changes are done at TDC.
#35
https://rennlist.com/forums/928-foru...his-noise.html
Seems it was bad tension arm alignment in my case.
#36
This:
#37
Has anyone reported damage from the cams moving with the crank at TDC? If the cams move because of spring pressure, why wouldn't they snap to a neutral, no-spring-load valves-closed position?
#38
Shameful Thread Killer
When the belt is removed, the cams will often spring to their position of least mechanical resistance. It will be some combo of least spring pressure on both intake, and exhaust lobes and without going into a lot of geometry, one or both might move up to say, 40 deg. There's no way for the spring pressure on the cam lobe forcing the valve back up will cause damage from another different valve striking a piston. In the absolute worst case, the spring pressure expanding will not have anywhere near enough force to bend a valve if it strikes a piston at TDC.
Once the new belt is ready to be installed, just rotate the cam back to it's tick marks line up, and thread the belt around the cam gear. No drama needed.
#39
Edit: I can probably stay in the weird club, but the DS cam rotated surreptitiously.
#40
Glad to say All is well just finishing up . Went super well detailed instructions helped also some Listers suggestions as well . engine started right up . (Happy dance) I did the job at 45 deg. One suggestion the at helped reinforce my install was to mark the old timing belt as well as the gear. i then transfered the marks to the new belt and this insured me I was in perfect time.. cranked it over a few times then assembled it to start. It Cranked and lit right off. Many thanks to all who gave advice.. Love this site.. tomorrow I am going to tear the top end down clean my injectors replace all fuel lines vac hoses ect. and paint it it is a hidous light brown color..
#41
so this begs the qustion of why my stock head S4, has pre loading on the cams at 45 and TDC, while other here have not. oh,,,,, i have a GT cam... thats could be the diff... BUT, i just got done doing the TDC method with a stock S4 and it had the one cam snap to 4 teeth off before it came to rest. could it be cam timing. obvsoiusly, this S4, is a stroker, but that doesnt make any diff, as the heads and cams are stock S4. it is timed at about near Zero , so maybe the S4s with slightly advanced timing are more on the cusp of a cam lobe and have equalibrium and dont move.. I know my car driver side only moved a few mm at TDC, but the 4 teeth on the driver side.
anyway, sounds like you have it handled. i dont think the marking the belt does anything either, because when you string the belt, you just get the driver side on first and make the belt taut between oil pump and cam pulley. then fit the belt over the pulley that is aligned on the passenger side with the tool or a vice grip (to hold the hex nut) and you are then done.... fit the belt over by moving things around a bit and you are ready to tighen the tensioner. rotate the crank 2 revs and double check things are aligned and you are good to go.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
That's an interesting comment about marking the belt too. Do you mark at the crank as well as the cam gears? Otherwise I don't see how you could ensure the marks line up since you start lacing belt from crank. Given that your cam gears are marked, I'm not sure I understand how marking the belt helps.
I've never heard of anyone damaging anything by leaving the crank at TDC.
#43
my 85 cam'ed S4, went only 1-2mm CCW on the right ,as you did, and on the left, 4 teeth on the left cam , but i think it was CCW. i cant remember now.
#44
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
I think mine only moved half a tooth on the passenger side.. probably because I breathed on it wrong.
Bill Ball and I timed the car at 45degrees using the 32v'r tool.
![](https://rennlist.com/forums/attachments/928-forum/732026d1369853545-mongo-s-first-time-timing-belt-water-pump-thread-imag0810.jpg)
![](https://rennlist.com/forums/attachments/928-forum/732027d1369853545-mongo-s-first-time-timing-belt-water-pump-thread-imag0809.jpg)
#45
