These custom made fuel hoses came with the car. The previous owner bought them via 928sRus. I asked Roger which hose was for what application, but I think I screwed it up over the phone. Per Roger one goes to the fuel cooler on the fire wall and the other (fuel supply from the tank) on the passenger side of the engine. It appears as though either of these hoses MAY fit either application so I'm at a bit of a loss...
The top hose goes between the fuel regulator / dampner and is being reworked. The hoses in question are the center and bottom hoses:
Does anyone know which hose goes where? And yes, I'm feelin' like a dumb-@$$ right about now...
Thanks in advance! Joel
Your car has a fuel cooler with female threads, so the lower hose goes there.
The middle hose is the fuel feed hose on the passenger side, which is directly above the exhaust manifold, which is why it is insulated.
I was hoping you'd chime in... Yes, that helps A LOT!! And, yes, I had Jake Myers fabricate a Bat Signal in LA for such an occasion... worked flawlessly!
Thanks again
