928 Forum 1978-1995
Sponsored by: 928 Specialists
Cheap water pump?
Old 11-01-2015, 02:06 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,719 Likes on 1,319 Posts
Mark, change the water pump. Get a Geba from Mark or Roger. One less excuse for WSIR in 2016.
Old 11-01-2015, 02:15 PM
James Bailey
James Bailey's Avatar
Yes.
Old 11-01-2015, 06:04 PM
mark kibort
mark kibort's Avatar
Originally Posted by mark kibort
its tough to replace something on a car that doent follow the normal "norm" use times. 8 racing seasons, new engine back in 2008, but i dont think more than 20-30k miles .. the belt looks good, keeping tension well, but is it a time element or a number of engine revolutions over time?
there are no excuses on my side Rob.... I need a pump thats not inquestion, the point was that, its tough to change the belt or know when its time on a race car.
now i have an excuse..
so, what is the Geba and why is it different than the standard aftermarket that ive always used. I get about 4-5 seasons ... In fact, i think i put the Holbert replacement water pump on the stoker engine, so it had more than 8 seasons on it.
Old 11-01-2015, 06:26 PM
Rob Edwards
Archive Gatekeeper
What is the standard aftermarket you've always used? Laso? The Geba differs from the Laso by still being available. It's either that or a factory pump, or some Commie Chinese knockoff, but if you put a $65 water pump on the stroker, millions of baby seals will die.
Old 11-01-2015, 08:28 PM
Hilton
Hilton's Avatar
Doesn't Ed Standke accept these cheap pumps as a modification candidate for his pump with the improved bearing setup which decouples the impeller from the pulley in the event of failure?
Old 11-01-2015, 09:27 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Is that pump still available?
Old 11-01-2015, 09:31 PM
polecat702
Vegas, Baby!
polecat702's Avatar
I sent Ed, the Porsche OEM pump after I pulled it for replacement with his Guardian pump. I'm guessing that I've got around 9K miles on the Guardian. I could walk out to the garage to furnish the exact mileage, but I'm to lazy.
FWIW, The Guardian is the way to go, if you have a interference engine!
Old 11-01-2015, 09:33 PM
bureau13
bureau13's Avatar
I don't know where he gets the cores, but he does still make them...I just ordered one!
Old 11-01-2015, 09:38 PM
mark kibort
what is the "gardian"... sorry, ive been out of touch with the aftermarket pumps.
I think the pump ive been using lll these years are Laso's. I think i tried the factory pump, but the plastic impeller came of the shaft too.
dont worry, im on the same page with you on the knockoffs. no way ill use something cheap on the pump or anything that can cause the engine to get hurt.
now, if "Geba" are available and Laso's are not, then the decision is simple. but, what is the cost of the pumps now?
Yes
Old 11-01-2015, 09:39 PM
MainePorsche
MainePorsche's Avatar
Yep. The Guardian is my next one on the change over.
Old 11-01-2015, 09:40 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
OEM? An aftermarket unit?
Old 11-01-2015, 09:43 PM
MainePorsche
Guardian water pump.
http://perfexmfg.com/EGDS_water_pump.php
Old 11-02-2015, 02:08 PM
mark kibort
Originally Posted by MainePorsche
mine has an '84 style pump... so i think i have to go laso again
Old 11-02-2015, 02:47 PM
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,474 Likes on 1,468 Posts
Originally Posted by Kevin in Atlanta
At that price it would be interesting to dissect it and see what parts they used.
I can't tell you what pieces are used today, however Mark Anderson (928 International) asked me to dissect one, when they first appeared on the market, to see if this was a product he could sell.
The bearing cartridge was a double ball bearing style cartridge (one ball bearing in the rear for thrust and one ball bearing on the pulley end for belt load), instead of a ball bearing/roller bearing cartridge (one ball bearing for thrust in the rear and a roller bearing for belt load).
The ball bearing application for belt load made this water pump completely unsuitable for use on the 928 engine, where belt loading on the bearing is very high and requires a very high quality roller bearing to survive for any length of time.
Perhaps they realized this huge inadequacy and changed the bearing cartridge after seeing failures.....I have not dissected one recently.....we were done with this water pump as an alternative and moved on.
BTW: For those of you interested, I have never dissected a Geba pump. The metal impeller is such a huge step backwards for 928 engines, that I can not rationalize using it.
Old 11-02-2015, 03:20 PM
notaguru
notaguru's Avatar
GREAT NEWS!
There's an even cheaper 928 water pump at http://tinyurl.com/oswdwow
Higher quarity, too. Just to eliminate risk, I might install two of them.
Quick Reply: Cheap water pump?
