FS: Leftover 928 Parts from my '79 Spyder Project - some later model too
#31
Update to this thread with parts marked SOLD and those still available.
- SOLD Shifter Coupling & Precision Shifter Ball Cup - $256 new $175 for the pair - replaced because of my Z06 6-speed conversion
- SOLD All 4 Brake Calipers with Rubber Lines (replaced by GTS brake upgrade & SS line kit) - $250 for all or $125/pair
- SOLD Pair of Brake Shields (removed as part of GTS brake upgrade) - $50
- A-pillar Trim (black vinyl - had a spare besides the 2 I had covered by Rob Budd) - $40
- SOLD Newer Style Center Console Upper Vent with all vanes intact - 1 locating pin broken (not compatible with my car that has the **** to the left of the vents) - $30
- Nice 928 Brake & Clutch Pedal pads with "928" in the nub pattern (upgraded to SRP Racing knurled pedals so removed all pads) - $25 for the pair
- SOLD Complete Clutch & Flywheel Assembly (replaced with pinned clutch as part of supercharger upgrade) - $350
- SOLD - Uncovered Console Sides - $20
- SOLD Brand New Porsche Crest Horn Button for Momo steering wheels - $50
- SOLD OEM Under-hood Cross Brace (replaced with 928MS polished one for bling & strength) - $50
- Door Wiring Harness (not sure which side - was in spare parts box)
- OB Front Passenger Seatbelt Buckle (attach to center tunnel - upgraded to GTS seats that have the buckles attached to the seats) Driver's Side Sold - $25
- Fuse & Relay wooden panel covers - black one still available - $40
- SOLD Gauge Cluster with Membrane (no bulbs - spare that came with car - did my Jager upgrades to the original)
- Glovebox Latch Assembly & Catch (no key - spare that came with car)
- Glovebox Wiring Harness (have 2 - created a separate circuit for the glovebox light and NB door panel lights)
- Complete set of Hard Metal Brake Lines - $200 (spares that came with car)
- SOLD - Horn Trumpet (tested and works - replaced OEM horns with 2 pairs of Bad Boy Air versions)
- Air Intake Tube (obsoleted by Supercharger upgrade with different intake & filter)
- Lots of Side Marker & Front Lenses & Lights (Installed clear front lentses & smoked sides freeing up the OEMs and the spares that came with the car)
- SOLD Complete OEM Headlight Assemblies with Buckets & Hardware (H4 upgrade parts came with the car - used those with an HID upgrade freeing up these) - $200
- 928 Oil Filler Cap & Screen (spare that came with car - supercharger uses a solid canister instead of the screen)
- All colored lines for vacuum lock system (replaced vacuum locks with electric lock kit)
- Complete Newer Style Rear Seatbelts - $150 (these are larger than the versions for my '79 and don't fit into the body recesses - didn't know there was a difference when I bought them)
- OB Secondary Warning System (2 parts - 1 complete and 1 missing the lens - buyer gets both to make sure 1 works - I installed a 12v outlet in it's place)
- Passenger Wiper Arm & Wiper (extra blade too - spares that came with the car)
- Pair of nice GT/GTS Black Leather 928 Seats (3 circular switches on both + heat). Small wear hole on driver's outside seat bolster, but otherwise very nice. $2,000 OBO (see separate ad with pics here - VERY NICE PORSCHE 911 / 928 GT/GTS BLACK LEATHER 12-way POWER SEATS with HEAT)
- Pair of nice Black Leather OB-style 928 Seats (3 rectangular switches on both). Could use a couple rounds of conditioning/softening and driver's seat needs a new elevator motor - all others work fine. $1,250 OBO (see separate ad with pics here - Fs: Nice ob 928 black leather 6-way power seats)
#32
Hi,
I have a 1984 928 that I have been working on for the past 3+ years . Do you by any chance have or know of someone that might have the complete instrument cluster P/N is 928 641 108 34. I've told that that is the only one that will work with a 1984 model. I also replaced the 3 piece real spoiler and replaced it with a real I piece spoiler. Now that created another problem I now need both the LT/RT and lower rear hatch window trim. Do you have any of these for sale? Please let me know what you have and what you want for them.
Thank you in advance
Mike
Mike
#33
Hi,
Mike
Mike
#34
Update to this thread with those parts SOLD marked as such
- SOLD All colored lines for vacuum lock system (replaced vacuum locks with electric lock kit)
- SOLD OB Secondary Warning System (2 parts - 1 complete and 1 missing the lens - buyer gets both to make sure 1 works - I installed a 12v outlet in it's place)
- SOLD Pair of nice GT/GTS Black Leather 928 Seats (3 circular switches on both + heat). Small wear hole on driver's outside seat bolster, but otherwise very nice. $2,000 OBO (see separate ad with pics here - VERY NICE PORSCHE 911 / 928 GT/GTS BLACK LEATHER 12-way POWER SEATS with HEAT)
- SOLD Pair of nice Black Leather OB-style 928 Seats (3 rectangular switches on both). Could use a couple rounds of conditioning/softening and driver's seat needs a new elevator motor - all others work fine. $1,250 OBO (see separate ad with pics here - Fs: Nice ob 928 black leather 6-way power seats)
#35
Archive Gatekeeper
Or in other words,
#36
Or in other words,
#37
Archive Gatekeeper
Just trying to move the merchandise.
