Part Number Please.....
1 Post
Hi everybody, looking to replace my Headlight Relay on my 82 5 speed...
They pop up fine, but no light I just want to make sure I order the correct Relay
Thanks!
Rick
Thanks!
Rick
Team Owner
Take the cover off the relay and inspect the contacts,
add some deoxit 100 to the contacts and try the relay
Basic Sponsor
Correct number 928 618 107 05
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Received 1,316 Likes
https://rennlist.com/forums/attachme...relay-1982.pdf
From this thread. Thanks Alan.
https://rennlist.com/forums/928-foru...all-years.html
Rennlist Site Sponsor
My apologies if you have already done this, but...
The first thing to do is to carefully clean both ends of each fuse and their contacts. WYAIT (While you Are In There) do every fuse. Use the fuse diagram on our website to make sure that you have the correct size in each slot used, and that there is no fuse in the slots that should be empty. Using good European-style fuses, not the cheapest available, will help prevent problems.
1 Post
Thanks, yes all fuses have been replaced and cleaned. Also today I pulled out the relay , pulled the cover off , it look perfect and clean I did Doxit it put it back together , reinstalled it and No change...... All other lights work and headlights pop up as usual . I did try wiggleing the ignition switch and tried high/ low beam lever. Nothing...
Thanks. Rick
Thanks. Rick
