Anyone rebuilding complex relays?
Outside of cleaning the tangs and running some fine sandpaper across the relay contacts themselves, it's hard fix them cost-effectively compared to just making a new relay.
Reminds me of spending an hour trouble-shooting a cheap Chinese relay for a scooter. It cost $7. Then I got the "good" brand for $8 and still had to move the pins in the connector.
Search is thy friend young jedi:
https://rennlist.com/forums/928-forum/726216-defroster-defogger-relay-repair-solution.html
I have replaced the transistors and capacitors on one of mine that failed by staying on and going to a very high temperature while draining my battery. I have not finished testing it yet.
Here are the parts I used that were ordered from Mouser electronics.
Mouser #: 512-BC32725BU
Mfr. #: BC32725BU
Desc.: Bipolar Transistors - BJTPNP -45V -800mA HFE/400
Mouser #: 81-PVA2A474A01R00
Mfr. #: PVA2A474A01R00
Desc.: Trimmer Resistors - SMD470Kohms Open 2mm Single turn
Mouser #: 512-BC32725TA
Mfr. #: BC32725TA
Mouser #: 512-BC557BTA
Mfr. #: BC557BTA
Desc.: Bipolar Transistors - BJTTO-92 PNP GP AMP
Mouser #: 80-ESK105M100AC3FA
Mfr. #: ESK105M100AC3FA
Desc.: Aluminum Electrolytic Capacitors - Leaded100volts 1uF 20%
Mouser #: 667-EEU-FM1E681
Mfr. #: EEU-FM1E681
Desc.: Aluminum Electrolytic Capacitors - Leaded680uF 25V ELECT FM RADIAL
I did not replace the trimmer pot as it tested out ok. Another list member found he had to replace a diode to get his to work after replacing the transistors and the caps.
The best solution may be what many do - never turn the rear defrost on.
Good luck.
Mfr. #: BC32725BU
Mfr. #: BC32725TA
Mfr. #: BC557BTA
Mfr. #: EEU-FM1E681
Good luck.
I had to check. A new 928.615.115.00 is $200?! OK... I'm in for replacing a few parts and seeing if it'll work.
The relay pictured in the other thread doesn't have coating on it, the parts are big and they're all through-hole. Looks like a good chance to get it working.
https://rennlist.com/forums/showthread.php?t=726216
Mfr. #: BC32725BU
Mfr. #: BC32725TA
Mfr. #: BC557BTA
Mfr. #: EEU-FM1E681
Good luck.
Mfr. #: BC32725BU
Mfr. #: BC32725TA
Mfr. #: BC557BTA
Mfr. #: EEU-FM1E681
Good luck.
There are other relays that are practically NLA, including the auto trans kick-down. Does anyone have the parts list for this one?
