Engine Fire
#122
I know i'm late to the party but is this a virgin picture when you found the leak? I mean did you remove the hold down bolt on the rail or was it missing?
Attachment 976444
Attachment 976444
#123
Hessank, that bracket with a hole in it is for a plastic clip which holds the harness in place, on the outboard side of the rails.
#124
Got it Hilton. I am not close to my car at the moment.Thanks.
I can't wait to examine my injector clips because I recently replaced all my injectors in the spring.
Thought I was safe (er) after I ditched the FP gauge. Now this
#125
If you run the newer style injectors the lower O ring retaining hat seems to hit the intake gasket which prevents them from moving and popping out, so that is helpful but not something to rely on.
I may have been scoffed at for suggesting zipties or safety wire in this role in the past but now I am thinking zipties are not going to have the problem that the clips have of not being seated right or being put on blindly and ending up upside-down. Of course you can get the injectors clipped in before installing the rail but not everyone does that.
You can get the clips for BMWs for a buck or two apiece on Ebay or Amazon. I also tried some GM ones and they did not fit.
-Joel.
-Joel.
