928 Forum 1978-1995
Sponsored by: 928 Specialists
Dash, Instrument Cluster, Pod, Console Removal and Restoration
Old 08-27-2015 | 12:09 PM
FLYVMO's Avatar
FLYVMO
Originally Posted by carnahanbb
Do you guys think I should replace the vacuum actuators while I have the dash torn apart? It'll cost at least $200 - $300 per Roger. Also, does anyone know what these taped off plugs are for? I found them behind the dash on the passenger side near the crash tube and HVAC vent.
YES!
You will not be happy after you put everything back and the 25 year old vacuum pods start leaking...do it while everything is apart, and not worry about it later.
Cheers!
Carl
Old 08-27-2015 | 11:04 PM
carnahanbb's Avatar
carnahanbb
Originally Posted by FLYVMO
YES!
Cheers!
Carl
Thanks Carl, that's not bad advice! I appreciate it.
Old 08-28-2015 | 05:51 PM
carnahanbb's Avatar
carnahanbb
Default What is this?!
I ran across these two weird wire connectors and wondered if anyone else has seen them when they've had their dash apart? Does anyone know what they are?
Old 08-28-2015 | 05:59 PM
Petza914's Avatar
Petza914
If it's a Black wire with purple stripe, I think that's part of the illumination circuit. See if it has 12v when you turn on the headlight switch.
Old 08-28-2015 | 06:55 PM
carnahanbb's Avatar
carnahanbb
Well, I think it's two different wires. One black and purple and one just black but I'll double-check tonight.
Old 09-04-2015 | 12:46 PM
carnahanbb's Avatar
carnahanbb
Does anyone else have any idea what these plugs / wire are for?
Quick Reply: Dash, Instrument Cluster, Pod, Console Removal and Restoration
