How critical is PS cooler on a track car?
#31
Well,she's in.
![Name: IMAG2188_zpssqv1yf2z.jpg
Size: 337.1 KB](https://rennlist.com/forums/attachments/928-forum/1228005d1501528286-how-critical-is-ps-cooler-on-a-track-car-imag2188_zpssqv1yf2z.jpg)
I need to fab up a mount for the reservoir, and had to drill new mounting holes since the ones on the OB didn't line up.
Now it turns out that I get to pull all the accessories off again because I need to loosen the Porkensioner mount so I can bolt on the Lizard vacuum pump mount. Good times.
#33
oh and the Cayman fire issue is well documented. ...the plastic reservoir and fittings melt.....dumping fluid on the exhaust. Watched one burn one day.....but there is no problem with heat
Where do you think all that energy being used to pump fluid ends up ?? Best answer is turns to heat.
#34
I installed a finned cooler on my PS system and left the metal can reservoir. Never had any issue with the rack or pump. At least one thing I didn't have to worry about......
#35
For years 911s used a simple trombone engine oil cooler up in the right front fender and works just fine.... until turbos needed a radiator.
Now, "where does the energy......." go? ahhhh, well most of it goes up in mechanical energy , which is not a lot by the way, and the efficiency losses in the pump will go up in noise and in heat. certainly not a lot, as seen by the temps ive seen in the reservoir. its not hotter than water or oil in their systems by any stretch. and certainly not hot enough to melt plastic. however, if the reservoir is placed in a cramped engine bay like a 911, then yes , plastic will melt, oil will flow and fires will start when the oil hits the exhaust.
there is an old saying ..... "coorelation doesnt imply causation".
why dont you do this for us all jim... why not tell us the temperature that you have ever seen or heard of for power steering flud... .Then, give us the melting points of the plastic used in the reservoir.
Ill give you a hint...... PS fluid doesn't melt plastic.... people do by designing systems putting them too close to hot engine parts!
here is a link if you dont want to guess, as you often do here: (by the way, 260F comes to mind for some but usually higher and the PS fluid aint that hot!)
http://iwww.plasticsportal.com/produ...+A3EG7+BK00564
