'83 Euro Heads on '82 US 4.5 Liter Block
the intake is 1.6" vs 1.5" diameter. If i was going to guess about power loss on the runners alone, i would say, it would be negligible. after all, the smallest most restrictive part of the intake is the AFM, with only 4.14 square inches area.
the U is 7square inches area
the throttle body is 4.9 square inches
and the euro runners are 2.01 square inches area each x 2 is 4.02A
and US runners are 1.76 square inches area each x 2 or 3.52A 12% diff
Former Vendor
So how hard is it to swap in a complete 5 liter engine from an '86 into my '82? I've found one that the PO dropped close to $6K rebuilding it and replacing all of the valves and such. All I'd do is replace the belt and the rubber products and try to drop it in. My '82 has a small head gasket leak so it needs considerable work to be done if I go through the effort to repair it. Thoughts on that approach?
my usual plan is:
re-ring
re-bearing
new head gasket
machine surface of heads... check for leaks in valves if heads are good
new water pump , timing belt etc....
but, what are you going to do for heads and intake?? all US stufff? might be worth getting the to end from someone for $2k or so used.
Former Vendor
the slight mods include re-routing the cold start ciruit (easy as you can just port that to a port in the plennum. (fittings already there , just a simple hose and clamp) plug the back head ports of the euro heads (as the US ports are used for cold start by fuel going to intake ports ) the euro heads have ports going to exhaust ports. so, you just plug those with the same plugs as the heads have in the front of the heads on the timing belt side. (very easy). then the only other thing to do is a slight mod to the idle switch and WOT switch, which the euro TB has a more modular connection (also easy).
notch the pistons at the machine shop to match euro 86 specs (easy)
re-ring, rebearing and check the heads out and install.
best thing to do is just do the proven suceessful way ... part euro 5 liter! just bolt the euro stuff on a 5 liter block
otherwise, best to find an entire car if you want a 5 liter 4 valver.
The bigger Euro S valves can be part of a substantial performance improvement to a stock US motor. This is documented in an article from VW/Porsche that Greg did back when he was a young puppy. It has charts and graphs that show performance gains from big valves, exhaust, (and cams?). I think there might be an image of the article on here somewhere.
Former Vendor
I should just put a supercharged Corvette engine in it and call it a day...
