928 Forum 1978-1995
Sponsored by: 928 Specialists
Recommended Batteries
Old Feb 11, 2020 | 02:18 AM
  #31
GregBBRD's Avatar
GregBBRD
Former Vendor
Originally Posted by dr bob
Cruising the local Costco, they now carry the Interstate H6 AGM for about $150. The standard lead-acid H6 is a little over $100, so I need to identify some extended-life benefit to justify the 40% upcharge for AGM in the 928. Thanks to the use pattern of the car, it will undoubtedly see the same maintainer use protocol that gives 5 - 7 years of useful life with a standard battery. Need to get out the calculator, but my seat-of-the-pants guess is that the AGM isn't the better choice financially.
I've given up on selling AGM batteries to clients, regardless of the brand. Way too many warranty problems. AGM batteries seem to not like to discharge very far and then be recharged. Perhaps appropriate for cars that are driven everyday, but they all seem to work very poorly in a 928 application, which may sit, slowly discharging. for a week or two.
Old Feb 11, 2020 | 11:29 AM
  #32
Antigravity's Avatar
Antigravity
Premium Sponsor
AS an option you can look at lithium... yes more expensive... but built-in WIRELESS Jump Starting, much longer life-cycle and if you let it over-discharge it will go to sleep and protect itself.
Old Feb 11, 2020 | 12:34 PM
  #33
worf928's Avatar
worf928
Which AG battery size would you deem appropriate for a 928 application?
Is the smartphone app required to make use of the battery?
What functionality does a client opting out of the smartphone app forgo?
Old Feb 12, 2020 | 12:36 AM
  #34
Antigravity
Premium Sponsor
HI Worf,
There is no Bluetooth Option on this battery... it is a WIRELESS KEYFOB that sends a signal to the battery. So you don't need an app. You get two with the battery... just leave one in your glovebox and the other at home for safe keeping... then if ever a dead battery just press the one in your glove box, start the car and drive away.
For sizing our books show the H7 also called a Group 94r. But if it has the same mounting as some of the other Porsches it can accept the H6, H7 or H8.
Last we have a product called the Battery Tracker that has an App and tracks the voltage of your battery at all times, and give you a real time voltage as well as 31 days or previous voltage readings and allows you to see if you alternator is working and sends you warnings if you battery is low on voltage.... and that is an App you use with your Mobile Phone... but its a different product.
Regards,
scott-
Old May 28, 2020 | 07:24 PM
  #35
Wrinkles44's Avatar
Wrinkles44
dr:
I just received my "new" 1984 Porsche 928S on Sunday and checking the battery tray started wondering.
My 1984 928S Owner's Manual calls for a "12 Volts, 88 Ah" battery. I am wondering why this discussion did not mention this?
Most batteries have ample CCA but they seem to top at 80 Ah. My 928 now has (by previous owner) an FVP94R battery with CCA 750 and RC 135. It is a bit smaller than the cradle size but still functional. If I replace it, what with?
Old May 28, 2020 | 07:37 PM
  #36
jpitman2's Avatar
jpitman2
In my part of the world DIN88 is a recognized battery code. Ask for an equivalent to that where you are. Here they are 340mm long x 175 x 175, and fit early 928 battery cavity. I think DIN85 will also work.
jp 83 Euro S AT 57k
Old May 28, 2020 | 08:10 PM
  #37
NIACAL4NIA's Avatar
NIACAL4NIA
Originally Posted by Wrinkles44
dr:
84 requires the bigger group 49 battery, the smaller battery can move around. Pepboys have the Bosch brand for around $120 and if you top off the fluid, they last a long time. Mine is 8 years old on 1986 928.
Old May 29, 2020 | 04:07 PM
  #38
Wrinkles44's Avatar
Wrinkles44
Thanks for the info. The group 49 dimensions seem a bit larger than what there tray is. However, I am going to PepBoys and have them make the decision on the size.
I have another issue that perhaps you may have suggestions to. The Owner's manual calls for the ATF to be changed at 30K miles intervals. The ATF prescribed for this transmission in Lubrizol 3216C. The Porsche dealership here in Albuquerque tells me they cannot change because they no longer service these vehicles (too old).
Any ideas?
Thanks again.
Old May 29, 2020 | 04:31 PM
  #39
NIACAL4NIA's Avatar
NIACAL4NIA
Any ideas?
Thanks again.
I got my Bosch group 49 from Pepboys online with a promo code for $120 about 8 years ago not sure the current price. The 1984 Porsche uses any Dexton 2/3/4 ATF and the transmission is actually built by Mercedes, any shop can do a fluid and filter change. The power steering uses the same Dexton ATF .
Old Jun 4, 2020 | 01:35 PM
  #40
Wrinkles44's Avatar
Wrinkles44
Which Bosch specifically? I see PepBoys offers Bosch S4571B. Is this the one you mean?
Old Jun 4, 2020 | 01:41 PM
  #41
NIACAL4NIA's Avatar
NIACAL4NIA
Which Bosch specifically? I see PepBoys offers Bosch S$%&!B. Is this the one you mean?
It's about 14" inches long. Here is a link:
https://www.pepboys.com/bosch-premiu...roduct/9073755
Old Jun 4, 2020 | 02:16 PM
  #42
Wrinkles44's Avatar
Wrinkles44
Thanks again.
It does not mention its Ah. Is it necessary to have the 88Ah the Owner's Manual calls for my 1984 928, or it is an irrelevant issue?
Old Jun 4, 2020 | 02:21 PM
  #43
NIACAL4NIA's Avatar
NIACAL4NIA
Thanks again.
Doesn't matter I've had the same battery on my 1986 for close to 8 years however, I live in San Diego California with an average temperature of 75 all year not too hot not too cold. Extreme temperatures kill batteries.
Old Jun 4, 2020 | 02:31 PM
  #44
NIACAL4NIA's Avatar
NIACAL4NIA
Thanks again.
If the previous owner modified the battery box to take the smaller 48 group, then just replace it with S4 battery size but make sure it doesn't move.
Old Jun 4, 2020 | 03:42 PM
  #45
NIACAL4NIA's Avatar
NIACAL4NIA
Thanks again.
The rule of thumb for converting CCA to Ah is dividing it by a 7.25 constant. For instance, if your battery is marked with a 1450 CCA, it represents 200 Ah. A battery of this rating should last for 25 hours while producing power of 8 amps.
