928 Forum 1978-1995
Sponsored by: 928 Specialists
Rear brakes dragging
Old Jul 10, 2015 | 09:36 AM
Petza914's Avatar
Petza914
Debrue, I have a pair of working rear calipers off my '79 from when I did my GTS upgrade if your interested in having a spare set. PM or email me at petza914@gmail.com and we can figure out a price. I also have a pair of fronts.
Old Jul 11, 2015 | 12:28 AM
mark kibort's Avatar
mark kibort
Originally Posted by Petza914
That clicking noise could very possibly be the brokenn parking brake spring that I mentioned in a previous post as it gets stuck on things as the wheels are rotating and once broken allows the shoes to get cocked inside the drum which causes resistance. The current replacements are an upgraded version. It's unlikely though that both sides would break at the same time.
I had that happen to me! but it was a clicking sound ! those little buggers!
Old Jul 12, 2015 | 08:49 PM
James Bailey's Avatar
James Bailey
the early cars the master cylinder each half is plumbed to one front caliper and one rear caliper.... in other words diagonally. So much different than the later cars.....
Old Jul 14, 2015 | 04:33 AM
The Forgotten On's Avatar
The Forgotten On
I had the same exact issue on my 81. It's brake system had never been touched even down to the blue bias valves.
I replaced the brake master cylinder and did the customary brake fluid flush and the issue went away, which is why I posted what I did above.
It could be an entirely unrelated problem but the seals are 35+ years old and could warrant a replacement if the fluid hasn't been flushed at regular service intervals like most of our cars.
Old Jul 14, 2015 | 01:57 PM
James Bailey
my point was you need to know which wheels are dragging....the early cars have two brake proportioning valves on the firewall. They have small internal passages and sometimes chunks get stuck in them which can lock up one rear caliper....
Old Jul 17, 2015 | 05:07 AM
Debrue's Avatar
Debrue
I check the e-brake it seems to be working fine
today I was parking on a slight incline and in neutral with the no brakes I could hear the groaning from the front brakes. They were definitely sticking.
so I was mistaken it is the front brakes not the rears that are sticking.
I guess that means master cylinder. Sounds expensive.
Old Jul 17, 2015 | 06:56 AM
mark kibort
its pretty easy to replace....
