Official 1982 "Great White" revival thread!
#182
Forgot to wire in the power cable for the wideband gauge.. whoops..gotta do that today.
started fitting in the rear seat delete panels. Should be done with this today, still waiting on the power outlet assembly to come in...
#187
And in other news .....
She runs AND drives!!!!
took her out on the road, and all I can say is WOW!!! She is a rocket!!!!
Pre test drive walk around:
ill post videos tomorrow after I get them from the GoPro.
#189
That is the plan! I’m a little scared of it right now.....the brakes are VERY spongy. I may need to bleed them again.....clutch is good, shifts great, but who knows. Temp gauge appears to work.....oil pressure gauge seems to work. Speedometer works, tach works. Dash lights work (very dim), all exterior lights now work. HORN does not work. Swapped 3 relays, no change, cleaned contacts under steering wheel, even replaced old rusty horns with new ones, still no joy(tested on battery).
#195
That is pretty awesome. Does this mean you are bonafide? You should have had Lori shooting the look on your face while driving. I think I would have enjoyed that just as much.
Good on you.
Good on you.
