'86.5 Track Car FS
In short
'86.5!
~2800#
313 rwhp!
5-spd/LSD!
sunroof delete!
Track ready!
Asking $5499 obo (genikz@yahoo.com)
Pictures: https://flic.kr/s/aHskeMzJXn
Videos:
Located in Fullerton, CA (SoCal)
Issues?
No windshield trim
Parking brake in-op
ABS in-op
License plate lights in-op
Minor dents (difficult to see)
Unsightly rear fender 'rolling'
Rear bumper cover has cracks
PS whines when cold (oil foaming)
Oil pan gasket and front engine seals replacement is due
Power steering system has a small leak
It's a track car
WP0JB0921GS862824
158 - radio, 'Monterrey'
319 - higher fan speed
418 - rubstrips
481 - manual transmission
490/494 - 8-speaker sound
533 - alarm
650 – sunroof
Engine
Brad Penn 20w/50
New flange head bolts (10.9, higher grip)
http://members.rennlist.org/porken/8...ngine_bare.jpg
http://members.rennlist.org/porken/8...gine_cover.jpg
http://members.rennlist.org/porken/S3HeaterBlockOff.jpg
PK crank breather system (no high rpm oil loss)
http://members.rennlist.org/porken/OilFillerLidWeld.jpg
http://members.rennlist.org/porken/O...rSurgeTank.jpg
Oil catch can
Tuning
S300s v4.0 chipset - http://liftbars.com/indexs3.htm
WOTpot (WOT AFR adjusted) - http://liftbars.com/images/WOTpotInst.jpg
No-Lift-Shift (dual rev limit, flat shift)
Fueling
New hoses
Fuel cooler delete - http://members.rennlist.org/porken/8...fuelcooler.jpg
'87 S4 FPR (55psi/3.8bar)
Stock 24# injectors (rebuilt)
Intake
TQrings - http://members.rennlist.org/porken/T...ngsInstall.jpg
New boots
Rebuilt MAF
New stock air filter
New air temp sensor
New Idle Control Valve
Gasket matched runners
New Throttle Position Switch
New TB/MAF housing rubber buffers (standoffs)
TB/WP
PorKensioner/PKT
New timing belt (Flennor)
New Laso water pump (metal impeller)
Cooling
$1000+ aluminum radiator
Newer hoses
New TempII sensor (LH/EZF)
Heater hose housing delete plate
928 Motorsports aluminum radiator
SPAL dual 11" electric fans w/housing - http://www.racerpartswholesale.com/p...23/SPAL_Fans_3
Manual switch to run one fan full time
Ignition/Electrical
New Bosch coil drivers
Newer Bosch ignition coils
New Beru spark plug wires (OEM)
NGK BP7ES 1.0mm gap (non-resistor)
New Crank Position (reference) Sensor
S4 knock sensor (sensor only) - http://members.rennlist.com/porken/86_5_KnockSensor.jpg
Light-weight battery
Power kill switch
Deleted
Airbox lid
Belt driven fan
Airpump system
AC pump, pulley
Vapor recovery system
Passenger side mirror
Door window glass/motor/regulator
Rear battery box
Headlights (but included with sale, and can be added back to the car)
Exhaust
HeX-pipe (originally Motorsports SLC) - http://members.rennlist.org/porken/PKHXPipe2.jpg
GT resonators
Drivetrain
Newer clutch
PKlutch (clutch stop) - http://members.rennlist.org/porken/S300sNLS_PKlutch.jpg
PKalm (driveline coupler helper) - http://members.rennlist.org/porken/PKalm_installed.jpg
Early 8-disc LSD (928 MS conv, tight)
Steering
Newer PS hoses, including rebuilt high pressure line
Newer rebuilt rack (with delrin bushings)
Momo steering wheel, quick release
Suspension
QA1 kit (16-way compression adjustability - 650#/450#) from Mark Robinson - http://forums.pelicanparts.com/uploa...1327507184.jpg
Brakes
Front calipers cleaned and re-painted
Drilled rotors, rear
33 bar rear regulator
SS braided brake hoses
Stock '86.5 calipers (4 piston=S4)
Wheels/Tires
Boxster 17", RA1s (spray paint black, 225/255)
Cup 2’s 17”, RA1s (235/255)
2 – Cup 1’s 17, RA1s (255)
Shifting
New shift coupler
New shift ball socket - http://www.928motorsports.com/parts/shifterballcup.php
New shift lever bushes
Factory clutch pedal spacer
Interior
Alarm delete
Interior delete
Panoramic mirror
Asphalt removed
AC/heater delete
I/O Port camera mount
Seat back brace, driver
Sparco EVO III seat
5-pt Crow harnesses (dated 2012)
Right side net
Left side window net
Fire extinguisher
928sRUs hatch receiver bushing
DEVEK roll-bar converted to full cage
Exterior
Fog light delete
928MS chin plates - http://www.928motorsports.com/parts/chinplate.php
Bosch Icon Wipers
New front spoiler/air dam
Sunroof removed (welded panel)
Rear bumper/bumperette delete
Sidemarkers delete (sanded/primed/painted)
Flat-tow towing kit
'86.5!
~2800#
313 rwhp!
5-spd/LSD!
sunroof delete!
Track ready!
Videos:
Issues?
No windshield trim
Parking brake in-op
ABS in-op
It's a track car
WP0JB0921GS862824
418 - rubstrips
533 - alarm
650 – sunroof
Engine
Brad Penn 20w/50
Oil catch can
Tuning
Fueling
New hoses
Intake
New boots
Rebuilt MAF
New air temp sensor
TB/WP
PorKensioner/PKT
Cooling
Newer hoses
Ignition/Electrical
Power kill switch
Deleted
Airbox lid
Belt driven fan
Airpump system
AC pump, pulley
Rear battery box
Exhaust
GT resonators
Drivetrain
Newer clutch
Steering
Suspension
Brakes
Wheels/Tires
Shifting
New shift coupler
Interior
Alarm delete
Interior delete
Panoramic mirror
Asphalt removed
AC/heater delete
Sparco EVO III seat
Right side net
Fire extinguisher
Exterior
Fog light delete
Bosch Icon Wipers
Flat-tow towing kit
When you say 'track car', does it come with an annual inspection from the SCCA or NASA?
It's like buying a plane, does it have a current annual? That means a lot when you say "track car" or "airplane".
I like that you have a right side net, however.
Pics: https://flic.kr/p/v5TAhk, https://flic.kr/p/u8AgAE
I've resolved all issues listed on the 2nd page, except for a rear tow hook, numbers and decals.
Good point. Yes, it does have a log book from NASA. The annual inspections have not been done, since the book was issued however.
looks like a good deal for someone!!
toe hooks front and rear?
Yep.... and that seat back brace wouldnt fly either. its too high, at an angle and connected to a part of the seat not designed for a seat back brace.
and if the seat is on a slider, it has to be made by the manufacturer of the seat. (e.g. sparco seat, sparco slider)
