I've used the simple set ( some csll it the Loaners type, I don't know what that means). I cheated by putting the lower hooks under the spring discs, not under the second lowest spring circle. this gave me a lot more spring length to compress so less force needed. But I guess a lot of mechanics will shout about danger now...
i must confess the mcpherson strut was out of the car, but compressing the dpring wss easy. i tried the real method clamping the second from the top coil and the second from the bottom coil but the coil was too strong
