Front ride height problem...
Except..to replace the adjusters..im still pulling the shocks..
Why do I expect a fair amount of energy to be released, if I cut a compressed spring?
Why do I also not think that the new 'end' of the spring would then sit in to the seat correctly if I did it that way...
that's fine, i like questions and the challenges, so let me just say, the end that you cut, fits perfectly into the adjuster. cutting the spring, i used a couple of clamps to relieve some of the pressure when the spring coil is cut. lt made a weak thump as we cut through the coil . you need two cuts to remove the piece.
this way, you can lower the car, might have a good chance that the height might be good. and if it doesnt, you have a stiffer spring you can use with the new shock adjusters for fine tuning ride height.
I've known this to happen when the mechanic forces the lower arm down to get the shock out. He's turned the lower link bushes out of their range, and they dont come back unless you loosen the caps for a moment and then re-tighten.
The answer is to loosen the 4 bolts that hold the lower link caps on, and get the vehicle on its tires. Usually just one full turn will be enough. Bounce the vehicle to settle the lower arm back where it used to be, then tighten the caps to spec. IF thats what the problem was, the ride height will be within range again. If that doesn't help, no harm done. Try it.
Hey..you have a tool to adjust koni struts I hear?
I thought it was improbable.
Impossible.
But..a 65mil hard mountain drive brought the drivers side down to 2 fingers high from the tire, and pass side to 3 fingers.
It was 2 -fists- high. Ive had em sit high, but..wow.
Problem..solved.
But, it's still coming apart again next week for new adjusters.
Impossible.
Problem..solved.
The shock perches are all the same, the shorter springs are on the later cars to make up the space for the adjusters. Thats..it.
Seriously? It dropped THAT much?! I work mostly on S4s. Never seen one with this much space after new shocks. Something like 6-8" when we first dropped it even with the LCA loose. You had the car jacked up the previous day to do the rotors. It didn't hang up this high when you lowered it then, did it? Regardless, thanks to Roger.
The S3 upper A arms are a tad smaller than the S4, so..the way to work them out is a bitch. Compressing the spring in place, I should be able to drop the shock out and leave the spring in place...I think.
when i removed these Konis from my car, and then installed new Sachs/Boges, I did not change the adjuster position. and had no change in the front height.
it would always sit up high at first, some pushing and bouncing of the front would settle it.
did you push in all the way, the piston, and turn them? that is how you adjust these.
