17 inch turbo twist alloys cup 3
hi ppl need some help please
I have a thread I started on Pelican which I need some help on.:
http://forums.pelicanparts.com/porsc...ys-my-car.html
The great members have convinced me to stick with 17" over changing to 18" so I'm looking at buying some to replace my buckled front alloys. whilst looking I found these for sale on ebay and for the price I have to have them.
http://www.ebay.co.uk/itm/261904473567?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
My rears are simply showing signs of aging they run 97% straight and will need a refurb at some point. So the cost of buying new compared to refurb cost these seem an ideal investment...if they will fit. I understand most things but this offset etc seems to go over my head a bit
The question I have is could anyone advise if these are a direct fit for my rears. would prefer no moding or change of tyres etc. will I need spacers?? or nut changing
The pictures on ebay show the Et no etc.
any help please thanks
For me it's the feeling of responsive handling when I turn the steering wheel.
hi
in London the roads are crap and the speak bumps are awful.
I prefer better handling and comfort over the looks. hence I'm sticking to 17 inch.
18 inch would be to much harder on the steering and the ride quality with all the bumps would make me scream.
can't find the right turbo twist alloys
ok its been to long and i cannot find a new pair of my 17inch for sale anywhere. ebay have them but no one could confirm they where spinning straight etc. so never touched them. i can find the 18 inch as below
http://www.ebay.co.uk/itm/301685739202?euid=4216a961e7ab4765a993a5a8b3dff762&cp=1
please can anyone confirm will these fit without any problems
please can anyone confirm will these fit without any problems?
But the ET50 (50mm) front offset will NOT be ideal for handling.
I ran a set of ET50 front wheels on my 87, and I would definitely not do it again.
They were twitchy, and bump steered, and tended to track imperfections in the road.
Your existing original front wheels have an ET65 offset, which gives a negative scrub radius.
The negative scrub radius built into the steering geometry gives the car handling stability.
As you decrease the offset, you reduce the NSR (an ET55 wheel gives a neutral scrub radius).
So anything less than ET55 gives a positive scrub radius, which leads to tram-lining.
I had my ET50’s on for a few years, including a couple different sets/brands of tires.
Eventually I switched to ET60 fronts and the difference was immediately apparent.
Just my personal experience, but I would not use anything less than ET55 on my fronts.
If you are specifically looking for Turbo Twists, I am pretty certain the OEM turbo twists were never offered in 17 inch. Only 18 inch. See this page for a reference on all the OEM Porsche wheels and offsets. http://www.944racing.de/felgengewichte.php
All of the 17 inch twists I've seen have been aftermarket, made by either Mille Miglia or more recently by Cup Edition, sold through Tire Rack. I have a set of used 17-inch Mille Miglias I picked up from a 993 guy.
