INTERFERENCE?
Ok, now that its still not clear...
Who is and where is Roger? (keep in mind that I havent been on here with you guys long and am not as familiar with you all as you all are with each other).
What is a porkensioner?
Why would I rebuild a 60,000 mile engine that has been babied? If I was going to swap engines, I have a 406 dual quad, roller, gear driven, 4 bolt main small block that I would drop in rather than another Porsche engine (forgive me purists, but no vehicle of mine remains stock once I decide to start modifying it)
I was wondering if in the event of a belt failure, would my valves be struck by the pistons.
as far as belt failure, its probalby just find if its a US 78 to 82 (4.5 liter) and 80% sure there is no problem with the 83 and 84 US.
Of course I meant with the belt displaced. I understand with the valvetrain working as it should that pistons and valves don't make contact. In my experience, the '80-'83 Euro is non-interference (meaning when the bottom end continues rotations while the valvetrain does not). The good news that from '78-'95, they are all non-interference when the belt is equipped and the timing is correct.
Too late, the porkensioner is in the mail! I spoke to Roger who looked up my vin and told me I had the 22nd of 3000 USA 1984 928s and explained that my car had a good many options not normally requested..
I am in da club!
I am in da club!
you kind of hinted that the valves were close if "carbon" got built up on the valves or pistons and they could "touch".. not so as you know. nothing gets even remotely close unless the belt breaks or slips ....or if you spin it up to 10,000rpm, you might get "float" where the valve is still hanging down and the piston can hit it... but in our motors, thats kind of impossible... and if you drop a valve, it will get hit too, but thats true of all motors, interference or not.
Right. I think you misunderstood. What I meant was that I know of occasions with S2 owners who reported bent valves after a belt failure. I also know of S2 owners who reported no bent valves after a belt failure. Clearly, the valves and pistons get very close AT THE LEAST on the S2 if a belt failure occurs. Obviously there are differences between those examples that should explain why one engine bent valves while the other did not. What's the difference besides the obvious fact that the pistons touched over here and not over there? Was there a difference in the dynamics of the engine internals? Valvetrain? Carbon buuldup? Maybe? I don't know. Just a hypothesis.
the little changes can make for some problems in engines that normally wouldnt have any upon a belt failure.
I did measure the contact of the valves pushed down in the EURO. with euro S pistons. there was .3" of travel before the valve hit the piston cut out..... if you think about it, if the cut out was .175" , then the valve would hit the piston without it at .125". the lift of the euro cams are about .4", so you can see, that with a 8mm lift US cam, (or near .3") with deeper cuts, it becomes a non interference engine. the euro 80-83 pistons have a .3" pocket., so you can see that any piston with a .3" pocket and up to a .4" cam , will miss contacting the piston, as the distance the valve takes to hit the piston face is about .125.
anyway.... this is all from memory, but i think it gets you in the ball park for the risk involved...... if any. its nice to have a Non-interference engine, because bending valves is a huge pain! (and cost). But i havent heard of too many belts breaking that hadnt required changing if they did fail.
You talked to roger so you are good to go.
84 USA #2874 suffered a tb break a few years ago. Stan Shaw had it re-belted. No damage was done. I bought it soon afterward and it runs great. Drove it today.
85 USA #1116. 32 V. Suffered a cam chain derailment last spring. Valves on right bank crashed. Symptoms were a rattling knocking sound up top for 6 months. My dumb *** self drove it anyway without making the effort to diagnose.
On '84 MY S2 it can be explained by early engines using same pistons as '80-83 S. Those should be non interference like all earlier engines.
As I understand it, there are many factors that determine clearance: manufacturing tolerance stack up*, head gasket thickness, carbon build-up, etc..
*e.g., a combination of parts that individually meet dimensional requirements, but combine to produce an undesirable total length not governed by any drawing or specifications, and/or not determined. Long rods, long crank throws, short block, "thin" head, thin gaskets, shallow piston pockets, long valve stems, etc. You can imagine a manufacturer calculating the odds and deciding there's no justification for the trouble of matching parts.
dont think the US 80 to 82 motors came with a 4.7, they were all 4.5 Liter.... the US 83s started using the 4.7 pistons and were all Ljet. the 80 to 83S engines that had a 4.7 , were euro.....and the pistons were different than the 84-85 LHjetronic euro 310hp version engines which had very shallow valve relief pockets. the 300 hp version of the 80-83 euro, had deep pockets, thus giving the compression ration differences of 10:0 vs the 10.5:1 of the later 84-85 euro version.
they all had about 46cc of volume... just add the gasket and piston cuts and see what you get. (normal 84 piston were 2ccs vs the 80-83 pistons coming in at 7cc)
Got the new unit from Roger. The porkensioner is a quality assembly. check it out, you wont be disappointed. I will let you guys know how it installs for me.
