Feedback of GEBA on metal impeller
If the vanes were reversed the water would flow in the wrong direction.
FWIW, The pump I recently pulled off my Murf car appears to be original from 1987 and I believe it was made by GEBA by virtue of the GEBA diamond logo in the casting as well as the "Triangle-P" OEM part marking. It has a metal impeller, naturally.
P.S. Does anyone know the name of the triangle-P mark?
-Joel.
-Joel.
Basic Sponsor
Joel,
That does not sound like a GEBA pump at all - see my earlier comments about GEBA markings. As they seem to have only been selling them for a year also unlikely.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Tell them 928 owners are stupid and want plastic no matter what. They are even willing to pay more for plastic which is properly held in place like last Laso version. Some people rather pay 1000 euros for new Porsche pump than use any metal impeller version. That should drive importance of this issue home to them.
Vegas, Baby!
![](https://rennlist.com/forums/images/ranks/veteran_navy.png)
![](https://rennlist.com/forums/images/ranks/veteran_marine_corp.png)
Why not get one of Ed's Guardian pumps, and forget about it? Mine has been run hard in the Nevada "furnace heat" for 3 years, and still going strong. Cost is comparable to Laso, Geba.
.....There might be some force along the axis of the pump shaft imparted by water flowing over the "top" of the vanes (between the vanes and the cone shaped surface in the block) but my fluid dynamics is too rusty to figure out if that would be a positive or negative pressure.....
Closed face impellers don't 'machine' the front plate (they just score it or jam), and give more consistent and better flow/pressure characteristics, because the loss/mixing at the front of the vane, because of the necessary working clearance, is eliminated.
Contact Ed who developed the pump. Here's thread with all the details .... https://rennlist.com/forums/928-foru...ics-added.html ... and here's his website ... http://perfexmfg.com/
Hi Jon
Points noted. But just to be pedantic, not sure you're right about 'if the vanes were reversed the water would flow in the wrong direction'. The pump would still be rotating in the original direction so would still push the water in the same original direction. No? Just markedly less efficiently. 😀
Dave
Dave
Open face impeller pumps always grind into the front pump case if the bearings are worn, as there is always a negative pressure at the intake and eye of the impeller, and a positive pressure behind. The suction literally draws the impeller into the front plate (block in this case), and this only happens because bearing slop allows it. A side effect of that axial movement is that it makes the seal leak more, which trashes the bearings more ... and then it's all over and leaking like a sieve.
Hi Jon
Dave
Dave
On the above point that you make, I beg to differ. Having had personal hands-on experience in pump design, research, development, and manufacture, including production of dies for injection moulding of thermoplastic pump components; I can confidently say that the cost difference between one piece in a die for an open, and two for a closed in the same die is trivial. Add one more operation to put the two pieces together and its still trivial.
On your second point, I think the accurate answer is more likely ... 'it depends on many design features'. Whilst your scenario of zero net output is possible, it is also just as plausible that the flow is reversed and diminished. There are so many variables that the only way of being certain is to try it ... I have on some closed vane pumps and they pumped in reverse.
Good to see you boys talking about pump design. If the pump is run in reverse it will still pump but the efficiency goes down the pan and in practical terms will likely be useless.
Arguably there is a design flaw in the 928 pump volute. For pumps to be efficient they need very tight clearances between the impeller and the volute. If a pump bearing fails it rapidly wants to become a lathe so to protect against serious casing damage industrial pumps are kitted with what we call "wear rings". If these rings are compromised during a bearing failure they are pulled and replaced.
In the case of our engines it is probably not practical to build such into the design given the small dimension involved. That being said and thinking about it a bit. that leaves me wondering what Greg [Brown] does when he repairs a damaged casing. I suspect he is machining the pump volute and probably inserting what in effect will be a wear ring to reinstate the correct clearances between the casing and the pump impeller given it is not possible to mount the pump further inboard.
The plastic impeller was a logical design to prevent the gouging of the seat. I have lost two plastic impellers over the last 16 years- both pumps had perfect bearings/seals as I could tell but the impellers let go- on one of them the hub cracked.
Maybe sound repairs are possible at a realistic price?
Rgds
Fred
Rgds
Fred
If all we are going to get are water pumps with metal impellers then doubtless this procedure is going to see more service unless the manufacturers can stop the self destruct tendency.
Rgds
