Dyno bet? My racer headed to the dyno on wednesday
Very little cam gear wear; must be the photos. If the belt's on backwards, then my track days are a true test that it doesn't matter?
Honestly I've never seen any indicators that belts are directional Sean.
D'oh, good catch Ken...I labeled that before my coffee kicked in ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
BTW I can trim my fuel pressure with my adjustable FPR. I'll only use the WOT pot if my mid-range AFR's differ much from my upper AFR's.
Mark
Mark
317!
giving you just shy of 10% :-)
Mike
Mike
Porken.... care to chime in?
Well we cut short as the storms were rolling in...but after 15 partial runs, I found the correct "clocking" of my MAF relative to fuel pressures and pulled a 304/304 with low 12's AF, so we knew we had the position right: I pulled off the dyno and hauled butt home fast to not get caught in the rain w/o windows, wipers, or on slicks
I tuned it on the highway by TWS before we got on the track...after replacing 2 bad plug wires with a whole new set: ran great all weekend, very strong, 12.8-13 AF's at WOT the whole weekend. Dunno the final dyno result...though I'll post video links later as they come in. I did go off-roading once as it poured both Friday night and Saturday night, got the car nice & muddy :/
well I was 304/304 with mid 11's AF below 5k and low 12's near redline, so I was rich on both areas I should have been leaner on...my experience shows that peak torque is ideal with AF's nearing 12.6, and peak HP about 13-13.1 or so. Damn MAF's are so finicky...esp. w/o the proper airbox to keep the air smooth. :/
I would be very surprised if you can get the AF to the 13s in the redline, max hp range, and get more power due to that.
Isnt the MAF ignored under WOT? I thought it was.
anyway, i was in the 10s and 11s before i pulled the fuel way back on my stroker motor. the injectors are just too big for the power of only 375rwhp, so, should have gone with your stock 85 injectors vs the 30lbers im using. at under 40psi. (I was at near 70psi with the 19s and 335rwhp, 12.6:1 AF originally and the smaller 5 liter motor)
I ended up near 55psi fuel pressure on 30# injectors on the Porken chips...clocking the MAF made a world of injustice as most of my dyno runs were aborted at 3000-3500 as my AF's were well beyond the 13 range. When I dyno'd the snot out of my second 86.5, I made peak power at about 13:2 AF, gaining about .4 AFR with every psi of fuel I took out until I reached 13.2, then it leveled and then began losing power again with more fuel taking out, so I put 3psi back in it and left it at 12.9:1 (302/296 at that time, 17 years ago). I still have a Kirban adjustable FPR and a gauge on my rail: 044 pump ensures I won't run out of pump like I did on my turbo car.
because are able to actually tune it with more than pressure, it doesnt really matter i guess. get that thing to near 13AFR and lets see how much power you get... if you get more than 5 or 10, ill be all over trying to lean out mine (still stuck in the lower 12s too)
