What are the best "aftermarket upgrades" for the 928?
#31
Many of the aftermarket "upgrades" are really downgrades or compromises at best. Some are just plan silly useless fixes to none existent problems. Quite often they arise because the real parts are "too expensive" whatever that means
The BEST upgrade is always going to be replacing the 20-30 years old items which were worn out long AGO ! Enjoy the car for what it is try to resist trying to make it something else.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
#32
Range Master
Pepsie Lite
Pepsie Lite
Adjustable rear links (ott), stiffer, adjustable roll bar, X pipe, hi flow cats, RMB, Murph SuperShark kit, 930 steering wheel, steering wheel extension, Zimmerman cast hole rotors, Aero mirrors, colored threshold insignia, Cup II wheels (18 rears), center glove box extension in ostrich, stereo upgrade, CD changer, clear corner lenses, analog clock, short shifter, GTS shift ****, and may I have yet to do.........
#35
Electron Wrangler
Bosch ICON's all around - longer than stock in the back. They work great, look good and the rubber seems to stand up to the heat/sun better. I never wear them out from wiping duties - they just disintegrate over time - these slower than others.
There is an old thread on it.
Alan
Alan
#42
Dave
#43
#44
Electron Wrangler
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Like Ken said
Upgrade the nut behind the steering wheel before it gives you problems. Lots of those are in very bad condition - stronger, brighter, cleaner are alway a worthwhile improvement, make sure it's not wound up too tight though.
Sometimes the best bet is to get it out of there before it causes an accident...
Alan
Alan
#45
Received 1,289 Likes
Alan
Alan
A lot of good info on the Bosch ICON's here.
https://rennlist.com/forums/928-foru...er-blades.html
