928 Forum 1978-1995
Sponsored by: 928 Specialists
What are the best "aftermarket upgrades" for the 928?
Old 03-15-2015, 10:32 PM
Daniel5691
Daniel5691's Avatar
Default What are the best "aftermarket upgrades" for the 928?
Hi
I would like some input and opinions on the current state of the art for aftermarket "upgrades" for the 928?
In particular, are there any common-sense improvements which can add
reliability and performance to a 928?
I'm not really thinking in terms of
wild mods, but, more in line with improvements that fall in the category of
typical maintenance and refreshing/replacing parts past their service life.
Any comments would be very interesting, and appreciated.
Thanks!!!
Dan
Old 03-15-2015, 11:33 PM
The Patman
The Patman's Avatar
I'm a big fan of the LED conversions.
With such a low output alternator on the earlier models the amperage savings of the LEDs is certainly helpful. The mod modernizes the vehicle, makes it more reliable (LED vs incandescent) and the exterior and the interior lighting is quite often a more vibrant light.
Even door and dome lights, often the cause of a drained battery draw almost nothing compared to originals.
Old 03-15-2015, 11:54 PM
Jetdriver69
Jetdriver69's Avatar
Borla stainless steel cat back exhaust.
If your state allows, CAT, air pump, emissions plumbing, engine driven fan and aux electric fan delete. Add a large electric puller cooling fan.
Jeez, i could go all night...
Old 03-16-2015, 12:53 AM
syoo8
syoo8's Avatar
The ones I've installed on my car, that I like very much:
- Greg Brown's fuel lines
- LED instrument cluster illumination
- New design window switches
Old 03-16-2015, 02:48 AM
Ranfurly
Ranfurly's Avatar
RS steering wheel - chunky and feels much better than the stock wheel
RMB - more for the sound than ant sort of gain
A suggestion as I am yet to install it -
S300 chip set - very excited about this, I'm about to find out what'll do for my car.
Old 03-16-2015, 03:00 AM
Ducman82
Ducman82's Avatar
I second the RS steering wheel. Much better than stock.
Just so many little things to get!
Old 03-16-2015, 03:14 AM
NoVector
NoVector's Avatar
- Porken tensioner
- Flexplate clamp (I have porkens but there's now others)
- LED everything--and add Ed Shierer's dimmer switch
-- I haven't tried the CREE headlights but will before it comes out of storage next month
-- The Daytime Running Light mod (relay w/ LED bulbs)
- Roger's/Carl's highflow exhaust w/ x-pipe and cats
- External filter for the PSD
- Breathing system mod; albeit I think the jury's still out on which is best
- And the metal 928 Intl belly cover has still got to be the best bargin; I don't think the price has gone up in 15 years...
Old 03-16-2015, 11:48 AM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Cup holder.
Modern tires.
Modern audio.
Old 03-16-2015, 11:55 AM
Bilal928S4
Bilal928S4's Avatar
What's the latest recommendation for the audio upgrade?
The units are getting much shallower as there is no CD or cassette?
Old 03-16-2015, 12:12 PM
xschop
xschop's Avatar
Megasquirt if keeping the factory engine.
Old 03-16-2015, 12:49 PM
Ducman82
Ducman82's Avatar
^^^^ yes! forgot about that.
Old 03-16-2015, 12:56 PM
bureau13
bureau13's Avatar
Have many people successfully Megasquirted these cars? I was actually expecting to see more threads and a large established base of setup info, but I haven't...I've seen more comments along the lines of "It's a pain, and won't be worth it because the stock system works well." I've always been intrigued by the idea though...
Old 03-16-2015, 07:01 PM
The Forgotten On
The Forgotten On's Avatar
Megasquirt in theory gives you the ability to tune to a much finer degree than the stock computers do. The issue is creating a base map that works with the engine which requires hours of tuning. Not to mention having to tweak software and firmware to meet your needs.
Sharktuning on the other hand is easy as the base tune is already set and all you are doing is improving upon the base tune to work better with today's more advanced fuels compared to what was available in the 80's.
Also, with audio, the speakers have gotten better for the price point and the amplifiers pack more punch in a smaller size and generate less heat.
I try to stick with speakers and amps made in the US and or Europe.
There are still a few companies like CDT (made in Buellton California) and German Maestro (new name of the old MB Quartz still made in the same factory in Germany) that make high end speakers for a fair price. Especially CDT.
You can hunt around on ebay for some good used high end speakers and amps for way less than what they were new, especially when you consider they were made using quality parts in countries other than China.
In other words, you get what you paid for.
Old 03-16-2015, 07:29 PM
The Fixer
The Fixer's Avatar
A Hot Woman.
Old 03-16-2015, 07:41 PM
davek9
davek9's Avatar
Originally Posted by NoVector
- Porken tensioner
All the above and add
Black Sea super bearings for TT
Oil fill breather deflector plate
Quick Reply: What are the best "aftermarket upgrades" for the 928?
