928 GT dies on idle
#31
Unplug the MAF electrical connector. Does it hold a rough idle? If it does it's the MAF or the electrical connector. If connector contact points are not corroded it's the MAF as everyone is suggesting.
My idle problem cleared up by cleaning contacts surfaces with lightly sanding contacts with fiberglass pencil sander and deoxit.
The MAF was just repaired (thinking that was the problem - it was faulty) but that resulted in no improvement to the situation.
#34
Fixed!
Had a friend come by to help diagnose.
After having MAF rebuild and LH tested and checking continuity and voltage on the connector, assume everything is good between LH and MAF. Starting over:
Car starts and idles fine with MAF installed but disconnected. Hardly runs and dies within 30 seconds or so with MAF plugged in.
Pulled the MAF completely and unplugged. Car fires right up and sounds good.
Plugged in the MAF but did not install. Car fires right up and sounds good.
While car is running, flip MAF over to install in car and car dies.
Short in the connector at the end of the wire plugging into the MAF!
I've ordered new connector from Roger and will be extending the wire harness and adding a new connector. Can't wait to be back on the road!
#37
MAF back and installed and situation much better, but not perfect.
Stalling at idle is much less often, and generally only occurs after car is well warmed up and after running at highway speeds. When exiting the freeway and stopping at end of ramp, RPM drops and dies half the time unless throttle tickled to keep alive. If engine does die, starts right back up again.
#38
Received 1,609 Likes
Does your idle switch work? (Does it close the circuit as measured at the ECU pins when there's no pressure on the gas pedal?)
#39
I tested it about a year ago when the problem arose; and I used the 928 Periodic Inspection.pdf to which you referred. Did the Idle/WOT switch test and the Idle Stabilizer test; both good.
I should probably do them again for a double check.
R Mace - 1990 928 GT
#40
macerl, see step 3 in my post #25 above. Have you checked that?
#41
Thank you. I will check these vacuum lines.
- 3) The manifold vacuum system is sucking-in fuel from one or more broken diaphragms in the fuel pressure regulator or the pressure dampeners.
- Pull the vacuum lines from each of these and see if the ends smell like fuel or drip fuel or if fuel comes out of the vacuum connectors to the regulator or dampeners.
#43
That's normal.
#44
Pulled lines: did not see or smell fuel.
The elbow to the aft fuel dampener was torn (hope not due to my efforts during removal). Replacing that elbow (local parts stores cannot match size of vacuum hoses exactly);
- what size does a 928 use to for hoses and elbows to properly fit on fuel regulator and dampeners, or is any close size that fits snug adequate?
The forward fuel dampener did not have an elbow, hose attached directly but it appeared to have a kink where bent from horizontal to vertical. Replacing that line and getting another elbow as well.
Or I may just purchase the vacuum hose kit and connector kit (however, it does not appear to contain any elbows.)
