928 Forum 1978-1995
Sponsored by: 928 Specialists
The LadyBug Thread
Old 02-20-2015, 01:25 AM
  #31
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,582 Likes on 1,248 Posts
The bolts at the rear end of the front suspension lower control arms shouldn't be torqued at all until the car's on the ground, then they get torqued to 88 ft lbs.
Good discussion here:
https://rennlist.com/forums/928-foru...lt-torque.html
I don't recall ever hearing about people having an issue stripping the frame insert for those bolts at 88. Certainly worth blowing all the schmutz out of the threads and using a little silver optimoly or Wurth HHK on the bolts, tho.
Old 02-20-2015, 01:30 AM
  #32
69gaugeman
69gaugeman's Avatar
Be aware that when you use any antisieze on a bolt, the torque should be reduced. Some say 10-20%. I use 10%. This is because reducing the friction of the threads allows for a greater degree of rotation with the same amount of torque. One of the reasons that head bolts are done by degrees of rotation.
Old 02-20-2015, 01:33 AM
  #33
Rob Edwards
Archive Gatekeeper
Duly noted- is the same decrement in torque used if using HHK?
Old 02-20-2015, 01:45 AM
  #34
Ladybug83
Ladybug83's Avatar
I used some Porsche NR Optimoly that I got from Greg
Old 02-20-2015, 02:00 AM
  #35
Captain_Slow
Captain_Slow's Avatar
Josh...I'm really glad you found time to post this thread. You've not providing DIY instructions. You're providing DIY inspiration. Awesome.
Old 02-20-2015, 02:15 AM
  #36
Ladybug83
Ladybug83's Avatar
The bolts at the rear end of the front suspension lower control arms shouldn't be torqued at all until the car's on the ground, then they get torqued to 88 ft lbs. Good discussion here: https://rennlist.com/forums/928-foru...lt-torque.html I don't recall ever hearing about people having an issue stripping the frame insert for those bolts at 88. Certainly worth blowing all the schmutz out of the threads and using a little silver optimoly or Wurth HHK on the bolts, tho.
Good thread rob thanks. I'll loosen and then re torque after its down on the ramps
Old 02-20-2015, 02:16 AM
  #37
Ladybug83
Ladybug83's Avatar
Thx
Old 02-20-2015, 09:10 AM
  #38
Captain_Slow
Josh - Rob is correct about the control arm cap bolts. The control arms need to settle (specifically, the rear bushings that are clamped in position) in so leave the cap bolts less than an 1/8th of an inch loose and drive the car a short distance and then tighten them to 88 ft-lbs while on it's wheels. I recall I had to experiment with techniques, doing it all by feel with only my arms under the car.
Old 02-20-2015, 10:36 AM
  #39
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Impressive job and write-up!
Did you make new brake lines from copper?
Old 02-20-2015, 11:23 AM
  #40
Ladybug83
Ladybug83's Avatar
Thx Wally. I cleaned them with 000 steel wool
Old 02-20-2015, 11:48 AM
  #41
Captain_Slow
I've never seen red stenciled service covers like you have. Are they original Porsche factory or dealer issue?
Old 02-20-2015, 11:59 AM
  #42
Ladybug83
Ladybug83's Avatar
Not sure. Bought them from another rennlist member
Old 02-20-2015, 02:57 PM
  #43
Ladybug83
Ladybug83's Avatar
I had some free time before work this morning so I loosened rear LCA bolts and made a note to self
Installed heat shields
and new washer tank. Old tank was leaking and was very corroded at the upper hose fitting which caused stress cracks.
Removed, cleaned, deoxited and installed level float in new tank
The new tank is not tapped for the lower pump, which, from what I can tell is used for the headlight washer system. I plan to delete the headlight washer system because I found melted wires under the dash pod from the button and going into the loom. I eliminated the relay for the system and cleaned up the melted wires so they wouldn't cause any trouble and I plan on installing an onboard charger in place of the headlight washer reservoir. So Im hoping to not have to tap the new tank. Just can't tell from WSM (very little info in chapter 92) or from PET if this pump is dedicated to headlights, or shared with windshield squirters too. Have to do some thread searching later on to figure this one out.
Old 02-20-2015, 03:08 PM
  #44
Rob Edwards
Archive Gatekeeper
Common wisdom on the filler neck for the washer fluid is to stick it in boiling water for a minute or so to loosen up the steel tube insert, so it doesn't rust out. I guess one could consider doing the same thing for the washer fluid reservoir.
Just be careful not to overtorque the hose clamp on its filler hose- 1-2 ft lbs max. It's not like an undertorqued washer fluid hose, at the top of the tank, is going to lead to catastrophic washer failure, in a state where your wipers are going to die of sunburn before they ever get used...
Old 02-21-2015, 02:59 PM
  #45
Dave928S
Dave928S's Avatar
What a great write up ... and a brilliant job
I'll also be following your progress .. subscribed.
Quick Reply: The LadyBug Thread
