Cam timing question/procedure?
Scott,
If you don't feel good about the 4 teeth thing, since you have the crank at 45 degrees, you can move your cam gears to the marks for TDC, then move your crank to TDC (0) and install the belt. Your valves are safe and you have everything lined up exactly correctly. This is the way I do it.
Practice does make perfect. I always notice that if there is a long time between timing belt jobs, it seem like it takes forever to get everything spot on. Go through several timing belt jobs in a row, and I can get everything lined up and back together just perfect in just a few minutes. Seems like the timing belt even slides on quicker.
It turns out it's a whole lot easier to use the "4 teeth" method at 45 degrees than the "spot on" method at 0. The cams relax very near 4 teeth with the crank at 45. I don't know why, but it's true. I spend a couple of hours last time getting the cams lined up at 0, using the 4 tooth method at 45 took about 10 minutes. It really is superior (if it works). I quit at about 10pm last night and hadn't gotten to rotating the crank to 0 yet. I'll know for certain in a few more hours, right now it's breakfast
I did, however, learn how to test the sensor without putting the whole thing back together and turning the key, and I can now take the car apart and put it back together without looking at the manual. I have no idea how useful this skill will be in the future...
I don't get how this works? I use a vice grip (set very lightly using the screw) to hold the belt on the cam, but not to hold the cam in position. What do you hook it up to to keep the cam from spinning under spring pressure?
If you are going to do this type of work yourself you would find it most helpful if you have Porken's 32VR timing kit and his bump stick. Fitting the belt and timing the cams [if needed] is dead easy. I witness checked the tming of my cams using clocks and when recevied the 32VR kit I checked the timing to ensure the correct marks on the kit lined up which they did. Re-timing the cams is then little more than a 10 minute job when all the obstacles are out of the way.
Before removing anything set the motor to 45 btdc on No 1 cylinder and mark the cam wheel with white paint to index where the teeth are relative to the notch on the cam cover. The bump stick fits over the hex and makes it very easy to tension the driver side cam in the manner Mark says - I found the belt slipped on no hassle whatsoever.
Rgds
Fred
Rgds
Fred
Since this sorry saga took place over two days, I had lost track of what actually happened myself, so I thought I'd re-read it from start to finish to find out where I'd become confused. Turned out to be easy.
Before beginning to take the TB covers off for the second time in a week I set the crankshaft on the car to 0 TDC. The reason I did this is the Kempf tool instructions say to set the crank to zero before checking belt tension. During the first cycle of teardown/rebuild the day before I'd forgotten to test the belt tension before closing and had kicked myself. Promising not to make the same mistake again I set the crank at 0 before starting the second round.
When the belt slipped after I removed the idler/tension assembly I was irritated. Shocked, dismayed and irritated might be a better description, however I quickly convinced myself this wasn't a problem; I knew the crank location therefore returning the cams to the correct setting should be easy. A PITA, but still easy; a "recoverable" error in judgement.
Since the driver's side cam hadn't come unglued I focused on the passenger cam, which had. My first mistake (which is documented very clearly in post #1 on this thread) was confusing the 0 TDC cam marks with the 45 TDC cam marks. Remember, the crank was at 0, yet I talked about using "0 TDC cam marks" I'd placed "years ago" to locate the cam. The 0 cam marks were placed by the factory and are cast/machined into the parts. I placed 45 cam marks (using a black laundry marker) years ago. In error, I aligned the passenger cam to 45 while the crank was at 0. To make maters worse, I didn't check the driver's side because the belt was still on the driver's side. I forgot the driver's side can move once the belt comes loose.
So after incorrectly re-assembling the whole thing and turning it twice to end up at 45 (not 0, 45) I discovered the cams were out of time. We should all now understand why, I certainly do. I have no idea what they would have looked like at 0, but the funny thing is the driver's cam was spot on with the crank set at 45 (should of course have been set at 0). So I, thinking swiftly, decided something was wrong with the passenger side, not even recognizing that there was something horribly wrong with both sides; I expected to see alignment on the driver's side and I did (but at the wrong crank angle). I hoped, but hadn't expected, to see alignment on the passenger side, but I wasn't terribly disappointed when that didn't happen, instead I just blithely prepared to shoot myself in the foot. As luck would have it, I was at the end of my day and ventured to pose a question on the subject to this list. Had I not done that, I would probably be looking at a smouldering heap of junk sitting on top of my lift as we speak.
I think this is a classic example of how expectations and misconceptions can skew our perception of the world around us in strange, interesting and sometimes extremely dangerous ways. The long and short of it is disaster was averted, and in my humble opinion, that's a very good thing.
END REPORT.
END REPORT.
Last edited by Pfc. Parts; Jan 15, 2015 at 06:42 PM. Reason: For effect. As in "fire for effect"
The order goes out this week...
Age is only a number.
If I like the bump stick better, would you consider keeping my ex-wife?
I'd just like to find a good home for her...
Oh! She likes riding in 928s. She just isn't all that fond of paying for the experience. In all honesty, I used to have the same feelings about the Space Shuttle.
Regards,
not to hold the belt, but to keep the tension. the vice grip, clamps onto the large hex bolt, not the 17mm nut. you route the belt and put it on the pulley and use the vice grip to keep tension once you have the mark set..... you can put a bungie cord on the vice grip to keep tension, or have someone hold it while you route it to the other cam and that cam pulley should be fixed at the right position, so the belt will just slip right on... tighten tensioner and you are done.
as good as that tool is, its not something you will probably need to do if you haven't loosened the cam nuts that keep the cam timing. the timing belt setting is something that is pretty straight forwared and doesn't need the tool. just follow what I laid out and it will take only a few mins and will allow you to use the TDC mark or the 45 degree marks (and those on the cam pulleys). then, rotate the engine to 0 TDC and see if everything looks like it lines up.
Sorry this subject keeps coming up, but I do appreciate the continued support from the 928 community; it's a pretty scary situation to get into the first time it happens. Now, I suppose, I'm a veteran and will walk through the valley of the shadow of death without fear in the future...
And I'll keep my eyes open for fellow travelers, next time perhaps I can be of assistance by passing on what I've learned.
