928 Forum 1978-1995
Sponsored by: 928 Specialists
Bad injector = park it?
Old Jan 2, 2015 | 10:39 PM
vanster's Avatar
vanster
Default Bad injector = park it?
I have an intermittent bad injector. I don't know how to figure which one.They have been cleaned (Witch Dr) recently however the one bad one won't clear itself out for about 150 miles of highway driving. Sometimes it's not a problem at all. My guess is that it's just worn out. Also I'm guessing that this will cause this one cylinder to run lean thus creating a catastrophic problem.
I only use Chevron gas and a bottle of Techron every few tanks will help but this is a bandaid solution.
Until I can get new injectors from GB or ? I should just park it?
Old Jan 3, 2015 | 12:02 AM
James Bailey's Avatar
James Bailey
get a cheap infrared temp sensor gun and see which exhaust port is cold....
Old Jan 3, 2015 | 03:20 AM
The Forgotten On's Avatar
The Forgotten On
Something even cheaper is to buy a noid light and touch it to each injector to see which one is not firing correctly.
Or the cheapest option is to pull the plugs and inspect them to see which one has been running lean.
Old Jan 3, 2015 | 12:08 PM
James Bailey
the temp gun is more fun all kinds of things need checked once you have one !
Old Jan 3, 2015 | 12:29 PM
davek9's Avatar
davek9
The Noid light won't detect a faulty injector.
It will only tell you if the electrical signal is at fault that triggers the injector.
Cleaning old injectors is OK, however there is nothing that compares to a fresh set of NEW Injectors, especially if you upgrade to a newer type, like three or four hole.
Injectors are wear items IMO.
Edit: if you are seeking a "short term" solution, figure out which one(s) of the eight are not working correctly and replace them w/known good ones, and save up for a new set.
That's what I did when three of mine were actually leaking on the Gold car, the new set of four hole w/ rebuilt MAF made all the difference in acceleration.
The spark plug and or IR gun are great suggestions to tell.
Dave
Old Jan 3, 2015 | 01:52 PM
danglerb's Avatar
danglerb
Don't get the cheap one, the area measured is too large unless its very close. The bigger ones tend to have a narrow focus allowing spot temps.
Old Jan 5, 2015 | 08:19 AM
M. Requin's Avatar
M. Requin
I got the HF 29.95 special maybe 4-5 years ago, accurate, impressive range, pinpoint. YMMV!
And Mr Bailey is correct, they are a gas to play with- I can't believe how often I use it. And serious stuff, too- brake rotor temps, wheel bearings, radiator, wiring hot spots, are the ashes in my fireplace really dead etc etc
Old Jan 5, 2015 | 09:33 AM
danglerb's Avatar
danglerb
That is the correct one, just not the $9 or $19 smaller ones.
Old Jan 7, 2015 | 10:00 AM
M. Requin's Avatar
M. Requin
And I thought I was cheap! (Tnx for the clarification )
Old Jan 7, 2015 | 11:13 PM
1989porsche928's Avatar
1989porsche928
just get a rebuilt set off of ebay. some http://www.osidetiger.com/ company makes a rebuilt set for 150
