Fancy New Air Filter Box
Howdy Fellars!
Dinsdale Piranha here.
Just finished this fancy new air filter box for one of the V 12 cars and figured y'all would get a kick out of it.
Fits under the hood and uses a stock size 928 filter.
Here are a few pics for your viewing pleasure.
Chronic Tool Dropper
For many, the process is at least as interesting as the result. Can you share some of the techniques and materials you used? Just seeing the plug and then the finished product, one might be decieved into thinking that the CF just magically appeared in that perfect shape.
The process is called lost foam molding. This is my first try so I chose to use fiberglass, I would rather have a cheap failure than an expensive failure. The carbon fiber is a plastic wrap from 3M called Di-noc.
Here are a few more pics
You guys missed the key word: LOST in the LOST FOAM description.
Good News is that you could probably make a mold from the new part.
I'm confused about everyone wanting one...isn't that custom-designed for the V12 setup? Are all you guys planning on rerouting your intake plumbing or are you thinking just have the cover up-front, for some underhood bling? Because it does look damn nice...
