MaxJax placement, with a twist.
#46
The motor mount project is not a rabbit hole.
No rabbit hole in known history (real or literature) is that greasy, grimy, grungy, dirty, disgusting and icky. :P
Put those woodworking skills to use building Dwayne's motor support.
The lift looks really nice. I'm horrible jealous.
But I'd have to build a whole new garage to be able to have one (yes, I'm thinking about it).
#47
Chronic Tool Dropper
Motor mounts -- a perfect way to 'break in' the new lift. Start off with shower curtains, half a case of engine cleaner for the engine bay, all below the waistline. Rinse, repeat... Then have a ball. The motor mounts and OPG project on the lift will save your back for sure.
#48
It really makes it nice when you can raise and lower the seat to get that perfect angle when working under there...
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#50
127" (outside) - seems just right, the arms easily clear the wheels going in, then about a 3" extension. Probably a 5-inch window driving in, side-to-side. If I watch my weight, I'll be able to get inside.
Herman, after pondering the coming work while sitting in the cheap rolling seat I bought, you're device looks pretty smart. I'm thinking a 12-way electric seat mechanism might be a good start....
