Fuel Regulators and/or Dampers
How likely are these things to fail? Should I really be thinking about replacing them just because I have the intake off? Can they just be cleaned--by me or someone else who knows what they are doing?
It seems to me these things are just about maintaining: 1) the correct fuel pressure, and 2) a constant fuel pressure. My intuition tells me these are likely simple parts with only dirt/gunk to fear. What am I missing?
Thanks,
Louis
Thanks,
Louis
I used to say leave them until they failed. Not anymore as more and more have been failing. I have been recommending that you change them all when you are doing the intake. They lasted 25-30 years, do it an you shouldn't have to worry about them again.
Wouldn't you start worrying about them again in about 2039, then?
Basic Sponsor
As Sean says most change them out. You can pull a vacuum on see if it holds. They can be changed later with the intake manifold in place.
Basic Sponsor
We stock and sell them all - all years.
For the 86 all three - 1 x FPR & 2 x Dampers are $391.45
One of the dampers is becoming hard to find OEM 928 110 202 00
Thanks,
Louis
Thanks,
Louis
Cheers
Sounds like these should be on the replace list.
I, too, got some gasoline on my finger when I rubbed against the left rear damper vacuum elbow reaching for the CPS. I didn't think that should be normal.
Is the external fuel pump hard to rebuild vs. replacing with one someone else rebuilt?
Former Vendor
There's a rubber diaphragm inside, which doesn't seem to be very happy with the "new" fuels that have different additives and alcohol.
Rebuild external pump? Buy a new one.
When they leak fuel into the air port your idle goes to crap. I have had good luck with Walbro fuel pumps. Inexpensive, drop in, made in the US, etc.
Looks like the fuel pump makes sense to replace too.
Louis
