Something is eating the relay in my HVAC control head
This is true only of the very early cars (up through '80) that have no relay for the clutch...
On all other models this is false and there is virtually no loading on the slider switch so no sense modifying it - the whole issue is that the load was movd to the integrated relay contact6s - which are also insufficiently sized for the load.. ergo they moved the problem elsewhere but didn't solve it...
Porsche screwed up here in both cases - and should always have mounted a full size (replaceable) relay on the CE panel for the clutch - it was just silly not to. IMO the correct fix here is really just to do exactly that - add a new relay on CE - there is always at least one spare slot. The relay for the clutch should also be individually fused - since it's at high risk of mechanical damage during servicing - makes sense this is located on the CE panel too.
Alan
Alan
Let me make sure I understand this correctly...
You suggest adding a relay/fuse to 78-79, where there is not...
And for later 928s, separating the clutch circuit from the existing relay/fuse (which feeds the HVAC head) by adding a completely new relay/fused circuit?
Thanks!
Electron Wrangler
Yes - I'd do that (and have done that).
'78-'79 Have no relay - switching is the circuit track wiper switch (creates issues over time)
'80-'83 Have a single pole relay in the HVAC head unit (this is the least overloaded stock config)
'84-'95 Have a dual pole relay in the HVAC head unit
For '78-'79 - Add a Bosch style SPST/SPDT relay & fuse on the CE panel using the existing clutch output wire to drive the bosch coil
For '80-'83 - Add a Bosch style SPST/SPDT relay & fuse on CE panel in place of the integrated relay use the existing coil wire to drive the bosch coil (via the exiting clutch wiring).
For '84-'95 - You still need a working existing relay (or a replacement) because it also drives a separate circuit. Add a Bosch style SPST/SPDT relay & fuse on the CE panel using the existing clutch output to drive the bosch coil*
* In the case where the integrated relay has failed on an '84-'95 car:
I'd replace the existing relay with a mini SPST relay to drive the second pole and add a Bosch style SPST/SPDT relay & fuse on the CE panel using the existing coil wire to also drive the bosch coil (via the existing clutch wiring).
I think these are the best fixes for this issue - a bit more work, but neat, tidy, well protected electrically, environmentally & mechanically and easy to document. The fuses & relays are then easily tested, swapped and are interchangeable with others already in use.
Swapping a failed later head unit relay with just a mini-SPST makes the rewiring easier and relay selection easier too (ratings are less important and there fewer & lower power connections to make).
Alan
Alan
Wow, Alan... I think I actually get what you're saying! Thank you for the concise response.
Boiled-down a little...
So in all cases, wire the clutch exciter circuit independently to an open relay/fuse on CE panel.
(I may need a little help on the backside... but I kinda get that too, just have never done it)
For 84-95, swap out SPDT for SPST relay on HVAC head.
(I may need help understanding what pcb terminals to use for the low pwr stuff).
Electron Wrangler
BTW its important to have protection diodes on the coil circuits - this means the relay coils and the clutch coil.
The stock head unit coil driver circuit already has a protection diode (reverse biassed diode to ground with reverse breakdown voltage of ~25v) so mostly that is covered. Later cars also have a supressor on the CE panel on the clutch driver line, the part that is important to the clutch coil driver is also just a reverse biassed diode.
These help protect the relay & switch contacts but also are needed on the "AC on" indication line to the ECU for idle load compensation on cars so equipped... This line MUST be protected in this way, ensure these don't get dropped or moved relative to the coil load they are protecting.
Alan
Alan
Wanted to close out this thread and thank everyone for the input. After evaluating the condition of the entire AC system Jim recommended against just swapping out the clutch coil and we decided to go for a complete overhaul. The following parts were sourced and installed by 928 Classics
Remanufactured Denso Compressor 80 to 89
A/C Receiver Dryer to 87 to 92
Front & Rear Expansion Valve 86.5-95
A/C Pressure Hose 87 to 89 (aftermarket kevlar)
A/C Suction Hose 87 to 89 (aftermarket kevlar)
A/C O Ring Set 87 to 88 Front
Thanks to Jim for showing some love to my non OB shark completing the repair on time and budget. I am enjoying my Black on Black S4 without sweating for the first time in months and am looking forward to my trip to Frenzy latter this month.
Former Sponsor
I supplied/continue to supply a fuse holder and instructions for installation with my rebuilt HVAC heads. My prices for rebuilding were too high and 928 International returned to their original rebuilder for their units last year, so this fuse is no longer included.
You should be getting one in the post that was a rebuild in 2009 which had failed, not one of yours, but I'm curious as to what the problem is.
