928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine Wiring Harness - New Product 928sRus
Old 07-02-2014 | 04:31 PM
Tom. M's Avatar
Tom. M
Deleted
Here's a pic of my harness... Had lots of weird issues like random no starts, loss of excitation circuit, oil level sender etc. When I pulled it, it appeared to have chafed on the area where it goes from the front of the block through and down to the starter. There is a holding clamp there that is usually not replaced when the engine is worked on (difficult to get to in the first place). After fixing it, every little gremlin I had before was gone....
Old 07-02-2014 | 05:03 PM
Gary Knox's Avatar
Gary Knox
Great addition to the parts we'll all need 'someday' if we don't already. THANKS Sean and Roger for getting this in 'production' and marketed.
Old 07-02-2014 | 05:06 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Originally Posted by SeanR
I made them as close to the factory as I could, plug and play even down to the wires are exactly as they show on the wiring diagram.
Biggest issue right now is finding the time to actually make them. I was waiting on parts Saturday so spent the day making the two that Rog has on hand.
Great news for owners with extra-crispy wiring harnesses. Kudos to Sean and Roger for taking this on.
Sean, have you built a nail-board yet for cutting and assembling these? More than a few limited-production-car harnesses are "manufactured" on a plywood panel with nails and temporary (velcro) wraps stapled on to hold the bundles as they are gathered prior to loom/sleeve steps. Guessing that the longest conductor is somewhere less than maybe ten feet (starter to jump post) so you could do it with just a couple bends. Guessing also that you could batch-cut most of the smaller conductors once you know the exact lengths (plus a nail-wrap allowance).
Alan and I have mentioned a few times the desire to improve the size of the primary power conductors, and to separate that and the 50 (white) solenoid conductors from each other and from the more sensitive conductors in the loom, maybe with glass wrap or Firesleeve. Since you are still early in the pilot manufacturing stages, this might be a standard or upgrade/option to offer.
Old 07-02-2014 | 05:26 PM
SeanR's Avatar
SeanR
Hey Dr,
I've got a board that I was using to hold the old harness so I could keep everything in place for measurement. The wife and I made a few spread sheets with measurements, type of wire, color, end connectors etc and so far found it simpler to read it and pull the length from the rack and cut. Then put the ends on.
I did think about keeping the BC wires separate and it would be easy to do so but have not thus far because I wanted them to be as close to factory as can be. I've got enough fire wrap in multiple sizes so I can do if anyone were to request it. As for wire size, I have BC4 to BC10 for primary as I initially made a couple with BC4....way over sized so picked up the additional sizes. One thing I noticeable is Porsche thought at the time a tinned copper was the way to go and everything and everyone I talked to said solid copper is how it should have been done. That's what I'm using.
I honestly didn't even want to take this sort of project on but had one 82 Euro that needed one badly and Porsche wanted $2600.00 for the harness. At that point it was simpler for me to spend that $2600.00 on wire/supplies/tools and get it done myself instead of wondering if Porsche was going to have another one when I needed. We used the last '87/'88 harnesses last month and they couldn't tell us when another would be in production. It's been quite the venture talking with so many different distribution centers to get the best price and the correct stuff. Has been fun. I told Roger last week to not announce anything as I didn't want more orders than I could fulfill. I guess handing him a couple of 87+ ones egged him on to post. I just want to keep as many of these on the road as we can.
I'm quite open to suggestions and as you said, still in its infancy here.
Old 07-02-2014 | 05:50 PM
ROG100's Avatar
ROG100
Basic Sponsor
Nothing like a little Peer pressure
Old 07-02-2014 | 05:52 PM
SeanR's Avatar
SeanR
LOL, do you really want your A/C to work today?
Old 07-02-2014 | 06:05 PM
MainePorsche's Avatar
MainePorsche
Nice job.
Looks good.
Old 07-02-2014 | 06:36 PM
Keith Coe's Avatar
Keith Coe
I want my a/c to work today if Roger doesn't!
Old 07-02-2014 | 06:42 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
This month?
Great job, buddy!
Old 07-02-2014 | 06:45 PM
Livio928's Avatar
Livio928
This is absolutely necessary. I just spent hours trying to go through my entire harness to ensure it is still in good condition but that doesn't mean that there couldn't be brittle wiring somewhere in the sheath that I didn't bother to check. If I would have known about this, I would have waited and just purchased a new harness.
Old 07-02-2014 | 07:16 PM
rgs944's Avatar
rgs944
Nice!
Old 07-02-2014 | 07:23 PM
M. Requin's Avatar
M. Requin
That's odd because I don't think I have seen any tinned copper on mine- just regular copper stranded. Tinned copper does have a major advantage in resisting corrosion (and being a bit easier to solder) which is why it is used in marine applications. Might double check that one. Other sailors here will check in on this I'll bet.
But man, what a great project, and what intestinal fortitude to take it on. Any signs of heat stroke recently?...
Old 07-02-2014 | 07:25 PM
MainePorsche
Originally Posted by Livio928
This is absolutely necessary. I just spent hours trying to go through my entire harness to ensure it is still in good condition but that doesn't mean that there could be brittle wiring somewhere in the sheath that I didn't bother to check. If I would have known about this, I would have waited and just purchased a new harness.
I removed, and rebuilt, the harness too - big time consuming, and exacting job. I pre-measured then replaced the large conductor lines with 1/0 awg cables. Inspected, repaired, re-wrapped the looms and cables - very time consuming and difficult job.
Old 07-02-2014 | 08:17 PM
rlich8's Avatar
rlich8
I'll vouch for this product. Installed one on my car in an effort to best ready it for sale. Great product.
Old 07-02-2014 | 08:52 PM
Bilal928S4's Avatar
Bilal928S4
Selling already?
Quick Reply: Engine Wiring Harness - New Product 928sRus
