GTS Engine Block - bored to 104mm
Developer
I have a GTS engine block for sale. These are very hard to find. This one has been bored to 104.0mm Makes a 6.0L motor when assembled with the stock GTS crankshaft.
Asking $2300
Green hue is the sealant placed on the cylinder walls to keep them fresh until the engine is built and run.
Asking $2300
Archive Gatekeeper
I'd stuff it with 968 pistons.
Basic Sponsor
That is 928 **** right there!
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Developer
What kind of pistons would go with this setup?
I would recommend this block be used for NA only in its current condition because of the wall thickness. If you wish to run it boosted, then I would sleeve it with steel liners for you.
Developer
Yes, I can and I have.
If you use the stock GTS crank (that has a 85.9mm stroke), this block with a 104.0mm bore will make a 5327 cc (5.8L) engine.
If I install our stroker crank with a 95.25mm stroke, it will make a 6472 cc (6.5L) engine.
To go larger, I would use a different block (no need to cut up a GTS block) and install wet sleeves.
I have built 7.0L 928 engines this way.
If you would like to read and see pictures of our steel LINER process for 928 engines, follow this link:
http://www.928motorsports.com/parts/dry_liners.php
If you would like to read and see pictures of our steel SLEEVE process, follow this link:
http://www.928motorsports.com/parts/wet_sleeves.php
Thanks,
Developer
Yes, I can. I will be out of the office until Wednesday, I will try to answer this then. Until then, there are several here who should be able to answer that question also.
No hurry. I'm still trying to decide what to do with a spare 5.0L block from an '85. It's isn't going anywhere soon.
