928 Forum 1978-1995
Sponsored by: 928 Specialists
Ringing sound on SC car
Old 06-05-2014, 01:30 PM
j.kenzie@sbcglobal.net
j.kenzie@sbcglobal.net's Avatar
Default Ringing sound on SC car
Hi guys
I finally got my fuel management unit working, and car is running strong. AFR on full boost is 11, at idle it is 13.5. I have developed a mid-tone ringing sound at idle that seems to come from the center rear of the engine compartment. It seems to go away with increased revs, or gets covered up. Manifold vacuum at idle is 17".
Thanks for ideas
Dave
Old 06-05-2014, 03:59 PM
Bilal928S4
Bilal928S4's Avatar
Air pump?
Old 06-05-2014, 04:18 PM
John Speake
John Speake's Avatar
Detonation ? oops, didn't notice this noise is at idle.... :-(
Old 06-05-2014, 04:48 PM
robot808
robot808's Avatar
Dave, you're using premium, right?
Old 06-05-2014, 04:55 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,719 Likes on 1,319 Posts
How far 'off' would you have to be to have detonation at idle?
Old 06-05-2014, 05:06 PM
victor25
victor25's Avatar
It's probably just a vacuum leak. When sitting at idle your at pretty much the strongest vacuum... -17 If you blip the throttle does it go away? If it does then I'd guess you either have a vacuum leak or its the idle control valve.
Old 06-05-2014, 05:16 PM
Thanks guys. Airpump is gone. I suspect a vacuum leak too, Victor. I will look more closely soon. I think a rubber hose stethoscope will help me.
Will report back.
Dave
Old 06-05-2014, 05:17 PM
Definitely using premium fuel.
Thanks Bob.
Dave
Old 06-05-2014, 07:12 PM
Hold On
Hold On's Avatar
Check all your intake clamps on 3in hoses. also at the AFM where the adaptor is. The blind inserts that keep the AFM from blowing back out, are a pita to get tight. The s/c still pushes a significant amount of air at idle. enough to cause a small whistle type noise at a leak. check any vacuum plugs you may have installed onto throttle body during conversion. also the vac hose that goes to the fuel regulator.
Old 06-05-2014, 08:18 PM
Thanks guys,
I have a little more data. The noise happens only when the car is warm. I was listening around and I decided to clamp the crankcase breather hose to the intake plenum. The sound stopped completely, and came back when I reclamped it. Carl's breather system exhausts his oil separator and cam tower vent into the plenum through a one way PCV valve. Clamping the final line stopped the sound tonite.
I am still not 100% convinced that there is not another cause, but for now I am thinking this way. I will check again tomorrow and look all over for vacuum leaks.
Breather system noise sounds benign, but annoying. I could look at changing the final hose diameter. We will see.
Thanks again,
Dave
Old 06-05-2014, 09:23 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,200 Likes on 1,241 Posts
Your breather system is plugged, the sound is the pressure building and finding a way out.
The pressure will find a way out and the next weakest link in the chain is usually the crank seal.
Old 06-05-2014, 10:14 PM
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,474 Likes on 1,468 Posts
Originally Posted by j.kenzie@sbcglobal.net
Hi guys
Thanks for ideas
Dave
Pistons rattling around inside the exhaust manifolds?
Old 06-05-2014, 10:23 PM
Thanks Hacker, you may be right.
Let me please ask how the noise goes away when I clamp the suction line to the plenum from the PCV valve? It seems I have too much vacuum, not too much pressure?
Also the PCV valve rattles nicely, and I can blow through it fairly easily. I understood that PCV valves are controlled one way valve that only allow a couple of inches of vacuum.
I will try asking Carl if I have done something wrong in my installation.
I really appreciate your thoughts on this.
Dave
Dave
Old 06-05-2014, 10:25 PM
No, seriously. I put a lot of stock in what you say, Greg.
Dave
Old 06-06-2014, 11:02 AM
Carl Fausett
Developer
Carl Fausett's Avatar
What I said to John today:
I wonder if your PCV valve is "humming" (cycling so many times it makes noise).
At idle, if your engine is nice and tight, you should be drawing a vacuum on that crankcase. That is a good thing. Off idle, there will be less vacuum, and I bet the noise you report stops.
You may remove the PCV valve if you wish for the noise to stop. It is a one-way valve. You noted you can blow through it in one direction but try to blow through it in the OTHER direction - it will not allow that.
The design is to allow the intake manifold to draw in crankcase fumes when the intake is under vacuum. However, when the intake is under boost pressure, we do not want the gases to flow in the opposite direction and pressurize the crankcase.
Carl
Of course, I have not heard the noise personally, and am only speculating based upon his description.
Quick Reply: Ringing sound on SC car
