Hub Cover Removal
#31
I'm not sure when I would get to it, so I wouldn't want to hold it to long.
I'm still having trouble visualizing jp's remedy with the screwdriver.
#32
at first ole Bob wondered what hub yer talkin' about... oooohkay, that one. I'm a stickler for greasing bearings and went there when I first bought mine. PO had done a crappy job of setting the clearance too. I have new bearings in a box that I really should install. I welded an attachment on a muffler clamp that works well with a small slide hammer.
Unless I can get jp's screwdriver remedy to go, I'll be using a double clamp arrangement with long bolts and my extractor claws in between the clamps. The slide hammer shaft will fit through the extractor.
#33
you can also make up the cup tool by purchasing a 2" black pipe end cap. and drill/tap it and then put in bolts. but the $2 clamp method worked for me
you can loan slide hammer at tool stores like O'reilys and Autozone
#34
I plan on using O'Reilys slide. I was thinking about making the instrument too. O'Reily's has on the shelf several spindle sockets and bearing lock nuts that would work for this application.
#35
Take a steel chisel and grind the sharp end "round" to fit the groove in the side of the cap, then tap a bit, rotate the rotor, and tap a bit, rotate, etc. and work it off that way. Grinding of the chisel point will minimize leaving witness marks on the cap.
#36
Chronic Tool Dropper
Wooden you rather use something a little softer to avoid the marks?
Gotta tell you that the hardwood scrap works perfectly, and leaves NO marks.
#37
I looked at the costs of 'new' caps from Porsche ($$) before I did the hacksaw flangectomy on my original pieces (for center cap clearance on some wheels). That steadied my hand as I did the cutting and edge finishing.
The relative ease of popping the caps off with the wood, couplked with the no-evidence factor, eases my decision on removal methods.
The red Mobil-1 synthetic grease is an exact color match for what the facory used on these bearings. Redline CV2 works too. For those who need concour wheel bearings...
