928 Forum 1978-1995
Sponsored by: 928 Specialists
Air pump filter
Old 05-18-2014, 11:39 PM
Cadillac art
Cadillac art's Avatar
Default Air pump filter
I discovered that my 1987 S4 is missing both the filter and the cap for the smog pump. Is this critical to replace before running the motor again?
It's my understanding that the pump puts air into the cat when the car is first started to help with emissions, is this correct?
Old 05-18-2014, 11:48 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
That is my understanding, too. If you are going to keep the smog system system you should replace those two items. I have them leftover from my 87 if you need them.
Old 05-18-2014, 11:58 PM
Cadillac art
Thanks Kevin. I'm near Denver CO. What would you be looking for for those items?
Old 05-19-2014, 12:02 AM
Bmw635
Bmw635's Avatar
Is there a way to keep the cap from popping off? Since I finished the TB, the cap from stay lock.
Old 05-19-2014, 08:21 AM
Kevin in Atlanta
My 87 came without the smog pump so I drilled a hole in the cap and the fan assembly and used a zip tie to permanently attach the broken cap.
Old 05-19-2014, 08:24 AM
Kevin in Atlanta
Drop me an email: 928parts@mindspring.com and I will fix you up.
Old 05-19-2014, 01:01 PM
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,257 Likes on 481 Posts
But Kevin, you can't put your beer there with the zip tie!
Old 05-19-2014, 01:45 PM
Alan
Electron Wrangler
Alan's Avatar
Kevin your lid is broken - the tab towards the engine should have the locking nub on it.
There is really no point fitting a filter until you have the lid - it will be bypassed.
New filters are easily available. Because of the way it works - its best to rotate the filter 180 degrees half way through its service life. You'd want to clean it off too - use a vacuum wand to get large debris out from between the filter and shell - then put it down the middle of the filter as you lift it out to get whats trapped at the botttom, and vac the bottom vent again after filter removal - lots of stuff just falls down into the elbow - not the very best of designs...
(Or get rid of the airpump - by the time I took mine out it wasn't even working).
Alan
Rexxus (10-24-2021)
Old 05-19-2014, 02:13 PM
Kevin in Atlanta
True, but, it is great place to hide some weed when crossing the border from Canada.
Old 05-19-2014, 02:16 PM
Kevin in Atlanta
Alan, correct. Here's the unbroken one I offered for sale:
Old 10-24-2021, 01:07 AM
Rexxus
Rexxus's Avatar
Default Broken air pump
Alan
how can you tell when the air pump is broken? How do you know when to replace the air pump filter? I noticed the hose connecting to the bottom of the air pump filter is broken and not air tight. Big deal?
Old 10-29-2021, 08:52 PM
Alan
Electron Wrangler
Alan's Avatar
I took it out and discovered it didn't pump anymore (whizzing it with an electric drill) - it did make some nasty noises though. I know that doesn't help you.
Two more practical options:
1) You could just see if you get any suction in the elbow at the bottom of the mini filter housing
2) When the car is warmed up you could see if it pumps air out the bypass port that connects to the CAI on the filter box lid (underside port on passenger side (LHD)) - just pull it off - if it flows no air as you rev it - it doesn't work...
Alan
Rexxus (10-30-2021)
Old 10-30-2021, 01:53 AM
Rexxus
Rexxus's Avatar
Default Practical options
Alan
I love that you knew
Quick Reply: Air pump filter
