928 Forum 1978-1995
Sponsored by: 928 Specialists
Broken door panel plastic repair tips needed
Old May 18, 2014 | 01:48 PM
prescott's Avatar
prescott
Default Broken door panel plastic repair tips needed
I took off my driver side door panel getting ready to replace the door hinge helper and add sound proofing. I found the plastic door panels thrashed by the PO or other mechanics. One old repair has white glue and chunks of a castrol can! This is my first try posting photos so bear with me.
Does anybody have a way to repair these bits, or is there a place to replace them?
Thanks!
Brian
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old May 18, 2014 | 01:53 PM
James Bailey's Avatar
James Bailey
there are stamped bent metal panels available which you rivet and glue to you existing pieces....try 928 International...
MjRocket's Avatar
MjRocket
I would go with these, not a cheap fix and you wont ever have to worry about them again.
http://www.classic9leathershop.com/s...8-automobiles/
Old May 18, 2014 | 01:56 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
thats what i used. they work GREAT....
Old May 18, 2014 | 02:03 PM
prescott's Avatar
prescott
Excellent! Thanks guys! Already ordered a set!
Old Oct 12, 2016 | 05:48 PM
Sagres74's Avatar
Sagres74
Veteran: Coast Guard
Recently took my drivers door apart and found cracks and broken plastic on the door panel. I've tried a few fixes but still not satisfied. Has anyone tried using ABS plastic with plumber's glue.
Also, if someone purchased the metal brackets from Classic9, could you pls post photos of the install and your opinion.
Here is my before and after:
Fwd bolt sections nearly gone.
Back section with major crack and missing section.
Post repair using the CastTape (carbon fiber tape with epoxy), epoxy over mesh tape.
Final product. Cleaning it up and testing its rigidness, the back crack reopened.
Old Oct 12, 2016 | 08:25 PM
Ed Scherer's Avatar
Ed Scherer
I got mine from 928 International ("Armrest backing support kit"), but I think they're identical.
I left these comments in another post:
Originally Posted by Ed Scherer
Installed the left side 928 International "Armrest Backing Support Kit," as I said I would a couple of posts back. That armrest was pretty floppy before; the left-most fastener wasn't really doing much, as the plastic part of the armrest at that mounting point was completely broken. The backing supports make a huge difference. The armrests are nice and firmly attached now. Highly recommended. I wish I would have installed these back when I first got them! Budget about an hour a side for these if it's the first time you've ever installed any.
Old Oct 12, 2016 | 08:43 PM
GJB928's Avatar
GJB928
I just finished that same repair. I used those plates in conjunction with Alumalite.
See here:
https://rennlist.com/forums/928-foru...bbit-hole.html
Old Oct 13, 2016 | 01:35 AM
Sagres74's Avatar
Sagres74
Thanks for the info! I'll definitely be ordering a set of the support brackets.
Old Nov 6, 2016 | 04:37 PM
Sagres74's Avatar
Sagres74
So, quick update: as posted above, I experimented with a few different techniques that left me unimpressed. I ordered the metal support bracket but kept experimenting with different products after some research on various forums, I may have stumbled onto the holy grail of ABS repair: ABS sheet with plumbers primer/glue. Now, keep in mind, what I'm about to show you was a poorly planned execution. Had I thoroughly thought it out, the end results would have been much better. But, I'll keep tweaking
Lightly sanded and ready for gluing using plumber's primer and glue.
Crack glued. Added a small piece of ABS plastic to help reinforce while I worked on the rest.
Made a paper template for the missing section and traced it onto the sheet of 1/8" ABS plastic.
Glued and setting overnight.
The front prior to shaping and drilling.
Drilled and shaped.
Same technique for the other side except this was on the front.
Back side.
Other side: notice the various techniques I used. Top left has the ABS on the front, fiber mess with epoxy on the back. Bottom right has epoxy tape with additional epoxy around the holes.
Final product... for now.
Old Oct 27, 2017 | 01:32 AM
Sagres74's Avatar
Sagres74
Recently I had to remove my driver's door panel to troubleshoot and then grease the window mechanism. In the process, I discovered that some of anchoring spots for the metal bracket had literary shattered. Kind of interesting to see plastic shatter like glass but I guess almost 30 years does some damage.
Since I couldn't simply install the bracket back in, I proceeded to try my ABS repairs again. Below some photos of the repair using sheets of ABS and plumber's primer and glue. I'm petty pleased with the results.
Lightly sanded damaged area.
Cut out the cancer.
Multiple cuts and layers.
The front.
Shaped and drilled.
Side by side comparison.
FInal product installed.
Old Oct 27, 2017 | 01:48 AM
chart928s4's Avatar
chart928s4
I had a lot less damage but it is obvious that plastic panel is not very strong. I'm not proud of it but was able to shore the one ruptured hole with JB Weld. It held very well but looks exactly as terrible you'd expect.
Old Oct 27, 2017 | 01:54 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
nice work on the restoration also i would suggest get slightly larger OD washers this will distribute the load over a wider area.
My guess for the plastic being damaged is from the use of Armorall ,
it wicks down into the plastic and causes it to crumble. JAWAG
Old Oct 27, 2017 | 09:54 PM
karl ruiter's Avatar
karl ruiter
After experimenting a bunch, I am pretty sure the parts are nylon rather than ABS. That means that pretty much no bonding solution will really work, or if it does work it will rely on surface adhesion rather than really bonding. I did have some success with cutting material out of doner part and welding it in with a soldering iron, but even that was very marginal. Also keep in mind that the material is failing not just because of age, but because it was never strong enough in the first place. My '82 door pockets were trash in '85. So you really need more strength than stock, and the steel panels get that for you.
Old Oct 28, 2017 | 05:05 PM
Sagres74's Avatar
Sagres74
Whatever material it is, this ABS/plumber's glue combo and the chemical reaction it creates works like a charm! In looing at some of my scrap pieces, the bond is inseparable. Last year's repair had held so strong thatI've beefed-up the other anchor points as well.
