928 Forum 1978-1995
Sponsored by: 928 Specialists
How about this one then!
Old 04-10-2014, 08:12 PM
  #31
dr bob
Chronic Tool Dropper
dr bob's Avatar
Welcome to the cult! Here's a little sip of Kool-Aide for you! Dulls the pain when taken in small doses they say.
Seriously-- Enjoy the car! The first ride home CLT to MEM is about the right distance. Short enough to do a same-day fly-and-drive, long enough to get comfortable with the car on the way home. I took a couple days (Denver to Los Angeles) and it was great, but I wasn't that happy leaving it outside in a motel parking lot overnight. Your drive will be spectacular, especially if you can deviate from the almost-all-I40 routing and find a few more interesting detours along the way.
*** Take Lots Of Pictures And Post Them Here. ***
Old 04-10-2014, 09:59 PM
  #32
polecat702
Vegas, Baby!
polecat702's Avatar
It's been my experience after owning an 87 S4 without rear air, and my current 89 with rear air, that the A/C worked better in the 87. The 87 was also black on black, where the 89 is black with linen interior, with black accents.
One thing I learned at 3rd coast last year was that Martin has a big 9 inch pusher fan mounted on his car's condenser, with front & rear A/C. He said that he discovered that the factory dual fan setup didn't pull enough air through the condenser to make the A/C work efficiently. His A/C will freeze you out of the car.
I've been thinking of doing this to my 89, considering the Vegas summers.
Old 04-10-2014, 11:58 PM
  #33
Hobibill
Hobibill's Avatar
@dangerlab
Check out the seats in this old R and T review of the 928s. Seems like they look the same even though they have cloth inserts.
http://www.caranddriver.com/reviews/1985-porsche-928s-road-test-review
Old 04-11-2014, 02:54 AM
  #34
Hilton
Hilton's Avatar
Congratualtions! (we hope!)
The drive home should be a great bonding experience.
Old 05-28-2014, 02:32 PM
  #35
Hobibill
Hobibill's Avatar
As you can see from the avatar, the lil red bird made it back to the nest just fine. I am, however, afraid every time I start it up since the timing belt is probably 27 years old. P-tensioner and new belt are on their way to me from 928srus. Will be needing some special advice once I get into that job.
Old 05-28-2014, 02:50 PM
  #36
Alan
Electron Wrangler
Alan's Avatar
Your dual AC in front only mode should have no appreciable difference to a front only system. There are certainly more failure/leak points but if its really worse than your '87 in front only mode there must be some problem with it...
Larger condenser capacity (either via better air-flow or bigger/better condenser) will help the dual mode capacity issue - so worth doing - but I'd investigate system health as is first.
Alan
Quick Reply: How about this one then!
