928 Forum 1978-1995
Sponsored by: 928 Specialists
Pan Spacer and Oil level sensor.....
Old Apr 1, 2014 | 01:20 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
Default Pan Spacer and Oil level sensor.....
Oil level checks out, but when i started it on a sloped drive way the light was flashing and going nuts..... sounds about right with a pan spacer. makes me think this drive up 8 from yuma to LA, i hear the hills are epic, are going to make me flinch if that light comes on....
has plenty of oil....
thought i would throw it out there.
Old Apr 1, 2014 | 02:41 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
Since the amount of oil in the pan is what determines the function of the oil level sensor system, the pan spacer will not affect this system. Only the dipstick will read incorrectly.
If you are using the pan spacer to move the oil level away from the crankshaft, the correct dipstick readings will be about 8mm lower than the marks. If you are running the pan spacer to be able to run increased oil volume, use the stock dipstick markings.
Old Apr 1, 2014 | 04:29 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
LOL, i have NO idea what my brain thought the sender was on the block...... wow i need coffee before i post.
i have the modded dip stick, and the oil is between the marks. just one steep drive i guess...
Thanks Greg.
