928 Forum 1978-1995
Sponsored by: 928 Specialists
928 roll cage??
Old Mar 29, 2014 | 01:06 PM
RPetty2's Avatar
RPetty2
Default 928 roll cage??
Hey guys, I know this is so strict racing forum, but for those out there with a 928 racer, do you know where I can get a roll bar kit at?
I tried summit but nothing looks right, I think a 1999 ford mustang gt would be close match. What do you guys think? Thanks
Old Mar 29, 2014 | 04:23 PM
James Bailey's Avatar
James Bailey
Close is not at all "good enough"....
Old Mar 29, 2014 | 04:56 PM
Ketchmi's Avatar
Ketchmi
I believe Carl @ 928 Motorsports still has them available...give him a shout.
http://www.928motorsports.com/parts/raceroll.php
Old Mar 29, 2014 | 05:16 PM
928 at last's Avatar
928 at last
Once again what Mr. Bailey said. If Carl is out of stock, get one done professionally. Not an item you want to half-a$$....
Old Mar 29, 2014 | 05:59 PM
White Lightnin''s Avatar
White Lightnin'
Veteran: Army
Your ever-present typos not withstanding... check your 928 racer bud Kibort for his recommendations.
Other racers like Mark @ 928Intl; Tom Falkenberg; John Veninger & Lloyd may have some insights as well.
928s are so uncommon, I would think a custom build would be the order of the day.
Old Mar 29, 2014 | 06:07 PM
James Bailey
He wants a full roll cage and not just an Autopower bolt in ROLLBAR....that said it has to be custom. The problem with trying to make something for another car work is you can not legally extend any tube which might be too short !! Plus getting it up tight to the roof is a challenge even when you cut and bend every tube yourself...and yes I have done that for a 928 cage I was bright enough to get it professionally TIG welded.
Old Mar 29, 2014 | 06:29 PM
IcemanG17's Avatar
IcemanG17
He already has a Devek 4 point bar. Plenty good enough for DE....only need a full cage one you start wheel to wheel racing!!!
Old Mar 31, 2014 | 10:35 AM
Courtshark's Avatar
Courtshark
+1 on what Brian said. I've also got the Devek 4 pointer. Gets the job done, and acts as a bonus sway bar, too.
Old Mar 31, 2014 | 11:39 AM
Carl Fausett's Avatar
Carl Fausett
Developer
I agree - do not confuse a bolt-in roll BAR with a welded-in roll CAGE.
BIG DIFFERENCE. We offer BOTH.
Our welded-in roll cages are here, with pricing:
http://www.928motorsports.com/parts/..._roll_cage.php
Lots of good info on that page - read it!
File Type: jpg
File Type: jpg
Old Mar 31, 2014 | 11:47 AM
Carl Fausett
Developer
I hesitate to make such assumptions. Race car builds start with getting the rule book for the race series you will be entering. Then design/build to match their specs. It may be you can add on to the roll bar you have. It may also be that you cannot.
Tube size, wall thickness, alloy/material, and gusseting are all items that vary from sanctioning body to sanctioning body. Number and location of side-impact door bars vary also.
Old Mar 31, 2014 | 12:31 PM
Speedtoys's Avatar
Speedtoys
What Carl said.
There is -no such thing- as a cage good enough for DE, but not race legal.
If its not race legal, it is determined unsafe enough to probably kill you easier than not having it at all.
Many sanctioning bodies, once they see 'race' stuff in the cabin, will look at it's legality to RACE with to judge of it's safe at all.
Cars go just as fast in a DE, as in a race...don't pretend that they do not.
$3k is not too much for a basic SAFE setup.
Old Mar 31, 2014 | 12:38 PM
Speedtoys's Avatar
Speedtoys
Awesome cage.
Some rule sets may judge the crossbar between the rear shock mounts as chassis stiffening, and apply big points.
Spec classes, although there are no 928 ones...generally specifically do not allow that in the rules.
Just a thought, if someone was doing a rules based classification setup.
Carl however..is not bound by those in his chosen classes.
Old Mar 31, 2014 | 12:41 PM
Speedtoys's Avatar
Speedtoys
Depends what its made of. I would never DE under something not legal to race with.
But that's just me..cages are cheap.
Old Apr 1, 2014 | 03:41 AM
mark kibort's Avatar
mark kibort
do a weld in cage... you don't need as many bars as carl has. that x is not really needed, unless you are putting it in a flimsy Bmw!
you can get a good cage done for 2k that would work well. 6 point with two parallel bars at the doors.
you also want the side bars bow'ed out a bit. that's too close to the driver in case of a side impact.
passenger dual bars should be higher as you don't want the front of a Miata to fit through that opening and end up in your lap.
the diagonal, might be a problem for the rules too, as I think it has to be in the middle of the horizontal bar. (not sure about this)
point is, you need to get this installed by someone that knows what they are doing.
u are safe making the entire cage out of DOM 1.75 x .095 thickness tubing.
also make sure you go to the installer and bring your race seat. you need to make sure the horizontal bar is at the right height for the shoulder belts. if they angle up from your shoulders to the bar, the cage will be illegal for most sanctioning bodies.
I can check with Borelli what they are charging to put in a cage. my guy did a few Grand Am GS cars, but I think he closed up shop.
